Hey all. Can someone please tell me what fluid i am best to put in my attessa system? I checked the reservoir on the weekend and its on the minimum line so i thought i better do something about it as the workshop that services my car havent checked it. Also do i have to bleed the whole system or can i just top it up? Any help is appreciated
Cheers Brad
https://www.sau.com.au/forums/topic/268442-attessa/
if it was me i would drain the lot, prob original nissan fluid in there. Recommended fluid is any Nissan matic-D ATF fluid, such as Transmax Z or Nissans own. But i am sure many people just use a Dexron III ATF fluid, although I wouldnt. once you have filled it, idle the car, check reservoir level, top up, connect clear hose to bleed nipple and release any air bubbles, again whilst it is running.
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4574343
and dont forget that there are 2 bleed points (in the C34 - NFI about the M35) one at the pump above the rear diff and another at the actuator at the back of the transfer case.
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4576649
ive got a 97 rs4 and the oil in the back hatch area is seperate from the oil for the transfer case. the oil from the hatch area activates a piston type setup which engages the awd. the transfer case at the end of the gearbox has a drain and filler plug in them. thats where the gearbox puts power to the front driveshaft. the oil from the hatch area was fine on mine and the transfer case oil was all burnt and black. that caused a shudder when the awd was under load. for the transfer case i used castrol transmatic z. for the hatch area i am unsure what oil to use. all i know is that it is very thin.
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4577815
Yes the transfer case has its own oil supply but the nipple right at the end of the gear box extension near the hose that goes to the attessa on top of the diff is for the Atessa not for the transfer case oil. Filling is via the reservoir in the boot and both bleed nipples are for the Atessa. The fluid for the Atessa is officially Nissan's specially expensive power steering fluid but i use a semi-synthetic automatic transmission fluid. So you can go to Nissan or use any good quality atf.
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4578842
oscillo hero Posted Yesterday, 05:44 PM ive got a 97 rs4 and the oil in the back hatch area is seperate from the oil for the transfer case. the oil from the hatch area activates a piston type setup which engages the awd. the transfer case at the end of the gearbox has a drain and filler plug in them. thats where the gearbox puts power to the front driveshaft. the oil from the hatch area was fine on mine and the transfer case oil was all burnt and black. that caused a shudder when the awd was under load. for the transfer case i used castrol transmatic z. for the hatch area i am unsure what oil to use. all i know is that it is very thin.
I have a shudder in my car under load. Im wondering if its the same thing. Not so much a shudder but a vibration in the rear at full boost. sounds like a good weekend job
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4580527
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
