Hey all. Can someone please tell me what fluid i am best to put in my attessa system? I checked the reservoir on the weekend and its on the minimum line so i thought i better do something about it as the workshop that services my car havent checked it. Also do i have to bleed the whole system or can i just top it up? Any help is appreciated
Cheers Brad
https://www.sau.com.au/forums/topic/268442-attessa/
if it was me i would drain the lot, prob original nissan fluid in there. Recommended fluid is any Nissan matic-D ATF fluid, such as Transmax Z or Nissans own. But i am sure many people just use a Dexron III ATF fluid, although I wouldnt. once you have filled it, idle the car, check reservoir level, top up, connect clear hose to bleed nipple and release any air bubbles, again whilst it is running.
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4574343
and dont forget that there are 2 bleed points (in the C34 - NFI about the M35) one at the pump above the rear diff and another at the actuator at the back of the transfer case.
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4576649
ive got a 97 rs4 and the oil in the back hatch area is seperate from the oil for the transfer case. the oil from the hatch area activates a piston type setup which engages the awd. the transfer case at the end of the gearbox has a drain and filler plug in them. thats where the gearbox puts power to the front driveshaft. the oil from the hatch area was fine on mine and the transfer case oil was all burnt and black. that caused a shudder when the awd was under load. for the transfer case i used castrol transmatic z. for the hatch area i am unsure what oil to use. all i know is that it is very thin.
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4577815
Yes the transfer case has its own oil supply but the nipple right at the end of the gear box extension near the hose that goes to the attessa on top of the diff is for the Atessa not for the transfer case oil. Filling is via the reservoir in the boot and both bleed nipples are for the Atessa. The fluid for the Atessa is officially Nissan's specially expensive power steering fluid but i use a semi-synthetic automatic transmission fluid. So you can go to Nissan or use any good quality atf.
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4578842
oscillo hero Posted Yesterday, 05:44 PM ive got a 97 rs4 and the oil in the back hatch area is seperate from the oil for the transfer case. the oil from the hatch area activates a piston type setup which engages the awd. the transfer case at the end of the gearbox has a drain and filler plug in them. thats where the gearbox puts power to the front driveshaft. the oil from the hatch area was fine on mine and the transfer case oil was all burnt and black. that caused a shudder when the awd was under load. for the transfer case i used castrol transmatic z. for the hatch area i am unsure what oil to use. all i know is that it is very thin.
I have a shudder in my car under load. Im wondering if its the same thing. Not so much a shudder but a vibration in the rear at full boost. sounds like a good weekend job
https://www.sau.com.au/forums/topic/268442-attessa/#findComment-4580527
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
