ok, here's my situation:
Did an RB20 build couple years back, all freshened up Rb20, all brand new internals bla bla bla, with an N1 oil pump. The first yead it went great, no major breakage, did 11.07 at 128mph.
The second year (last year) dropped it to 10.89 at 131mph, but with a major oil pump drive malfunction,
So this year, went and bought a collar, had it installed on the crankshaft. Again went with a N1 oil pump new from Nissan. Did my best so far, 10.42 at 125mph. And again lost oil pressure completely, dismantled the rb once again to fing my ''less than 20km of use'' N1 oil pump destroyed!!!!
So here's the questions to the knowledgeable people on this board:
1- Can dropping the clutch (engaging it) at 7500rpm at the launch make the ''little slack between the collar and oil pump drive'' break the pump?
2- Is there a miracle recipee (specific collar with specific oil pumps) out there that can permanently cure this problem?
3- Is it an actual oil pump drive problem or a balancer pulley (vibrations) problem like I heard from shops near my place?
4- Anyone had this problem before even with a collar?
thx for any info, and please, if you don't know the answers, please don't post anything, even if you want to tell me that there's other posts like this one.
regards
Sylvain
Edited by FastRB20
For starters, using the N1 pump for serious drag racing is not the best of choices.
TOMEI or JUN pumps are far stronger than the N1 pumps.
Then again those pumps can fail if not properly mated to the collar.
A crank that is not finely balanced will also cause you problem.
I used an N1 oil pump on my 10 second GTR for years...it survived lots of 8000 rpm launches by my wife Stacey and quite a few 9000rpm launches by myself. We turned the launch rpm up to 9500rpm and used a hard cut ignition rev limit as opposed to the soft cut fuel rev limit we used previously and it broke the 2nd pass we ran it. Running a properly balanced
engine assembly and using proper crank damper will help it survive.
lesson...use a soft cut rev limit, use a sensible launch rpm, properly balance the engine and use a better harmonic balancer.
Edited by DiRTgarage
Agreed!
Whilst the pump might have a weakness, its as much about how you actually treat it as opposed to anything else.
Hard/sitting on the limiter is BAD and will destroy a pump, hell you can kill a JUN pump in the same way if you abuse it.
rb20 - 131mph
FARK YEAH!!!
now ive got that done with
if u want the best of the best (for non external pumps) go tomei pump with collar and ati harmonic balancer
a little bit cheaper but still fairly good go a jun pump and ross balancer
or just go all out with a external and you shouldnt have any problems (will be expensive)
You should be able to set up a wet sump external pump for not a great deal more than using a jap brand name pump. As the TOMEI pump is around $2200 aud. You can buy a peterson 5 stage pump for less than that so I would imagine that a 3 stage pump would be relativly cheaper again. Add in associated brackets and a bit of fabrication on your stnd oil pan and I would think that this could possibly even end up cheaper to set up especially if you are handy with fabricating some of the stuff yourself. and hey presto no more broken oil pumps. As it seems that your set up is for drag racing it would be quite easy and not going to pose you any danger to set up an engine kill switch that is refrenced by oil pressure to save the engine should you lose a belt etc.
yep
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
