Hi guys just been epa'd so had to pull the highmounts off and put the standard turbos back on.
Ive got the gtr airbox just cant seem to find all the rubber and plastic pipping that comes off the intake side where the twin turbo pipe is.
Im in melb and in desperate need. Located in port melbourne. but will travel or organise freight.
Cheers somebody out there please help :P
Hi man
I have everything you need 300.00 this includes
both flexi pipes that go from amm to front mouth of turbos
the two outlet pipes and the small wedge piece for front turbo;
the pipe that joins the two turbo outlet that runs parellel with block marked twin turbo
the rubber hose that goes to the inner gaurd adapter for intercooler
there will also be the plumb back pipes and bends needed for job
we are talking about alot of bits also i will supply all hose clamps anr joining hoses.
all this should fix your problem
If you want ostage i recin about 60.00 to 70.00
regards stuart
