Hey guys i would wondering is it possible and if so how can you add things such as say a tilt sensor or auto window lifters to an alarm, I have the M80 with shock and microwave sensor which takes up both ports, Can i cut the wire and piggy back ?
https://www.sau.com.au/forums/topic/268492-adding-accessories-on-my-alarm/
yes you can , take it to the shop that installed it or risk" VOIDING "your warranty or insurance issues if stolen. "simple diode isolation of sensors" but might register as a bonnet impact when the window is broken , based upon led flashes or beeps when disarmed
to isolate them you need multiple input channels to know what happened to set them off, if you dont have any left it registers as whatever its connected too? if that makes sense ?
the window up/down portion maybe, if you have multiple function buttons on the remotes.I dont have the mongoose manual in front of me to say 100%
if not you can wire it to go up when armed with a relay.
Edited by sapphiregraphics
window control - doable anyway regardless of alarm.
as for adding on:
yes, m80 has two ports on it if you have the G model then both are used and its time to get the isolation diodes out.
mongoose make a Y harness for that app.
best to get the shop that did it to mod it.
