can't touch this! woa, woa, can't touch this! I still remember the crappy video clip too :D
we got some dodgy stuff here at work, gets pulled out on a friday sometimes. Good for a laugh..
i've got the astroboy theme song somewhere on here :) ROCK!
Originally posted by Jamezilla
Clarkey: I'll take it :D
Nismo: I have that as MP3 - you want?
Only if its like 320kbps and sounds nice & clean! - I do have it on mp3 but most of the ones out there are crud quality rips :)
...when I can be bothered I will hook my decks back up to my PC and transfer some vinyl to .wav / .mp3 etc...
:Dj:
Hey
there was a tmnt movie cartoon and two movies wasnt here?
how good was the cartoon movie. it had baxter in it and he was trying to take over a building or something to that affect. does that sound right?
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
