Nissan S14a 200sx 1998 model aus spec, manual.
Immaculate condition throughout, 2nd owner, gen low 110kms
$5000 custom respray in BMW M3 colour stratus grey in 2007 still in perfect condition
Modest modifications including - FMIC, 3inch exhaust, exedy cushioned
button clutch, z32 airflow meter, tomei rocker arm stoppers, nismo 550 injectors, blitz spec r boost controller, bosch 040 fuel pump, blitz turbo timer, apexi power fc.tuned at chasers motor works at a reliable 200rwkw,
Serviced every 5000 kms, alloy wheels measuring 19x10 rear and 19x8 front, 12 months reg,
i have owned the car for the past 5 years and has been very reliable, inspections welcome, regretful sale due to work commitments, first to see will buy.
Call 0433 350 905.
$16 000 ono
https://www.sau.com.au/forums/topic/268533-1998-200sx-s14a/
  • 3 weeks later...
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
