Hey guys,
Well I got an R33 GTST and im having this problem. The car turns off while im driving. It has happened twice now ahwile apart it happens from stop start going through gears then all of a sudden it turns off. Anyone know what could be wrong with it ? It seems to be idle'ing a little low would that have something to do with it ?
https://www.sau.com.au/forums/topic/268544-turning-off-wtf/
check the basics and go see a mechanic
reset the stock ecu, check belts, plugs, fittings in the engine bay
check for any loose plugs or connectors
check the afm plug
check throttle body etc for anything loose
check battery voltage at idle
https://www.sau.com.au/forums/topic/268544-turning-off-wtf/#findComment-4575767
try and replicate the problem while watching ETCl, SENSOR SW CHECK
on the hand controller
do any of the sensor names go black background or do you notice any wierd values
ie; a shagged throttle body or tps would show TPS with a black background when it goes out of range
https://www.sau.com.au/forums/topic/268544-turning-off-wtf/#findComment-4575899
Sorry to get in on the other guys thread,
i reset the power fc back to stock r33 base map, fuel pump is new and was fine the past month
im still running the 044 fuel pump but with stock injectors and afm,
will try checking the sensors wen it happens,
it happened just before at 10kmph the car behind me almost smashed into me as its like i hit the brakes then it throttle cam back on 2 secs later and was all back to normal
Edited by FOOLBOOST
https://www.sau.com.au/forums/topic/268544-turning-off-wtf/#findComment-4575927
Had a mate that had this exact problem with his STi, car would just randomly turn off, turns out his ignition barrel was shagged or something and it was rattling loose when driving and turning the car off, new ignition barrel later and a new set of keys and it wa fixed.
https://www.sau.com.au/forums/topic/268544-turning-off-wtf/#findComment-4576381
Thanks guys was my AFM the wiring even though soldered must have been touching as the afm keep dropping out
all fixed now :)
Mine did the same thing, in the end was dropping out every couple of k's whilst driving, turned out to be the afm as well.
https://www.sau.com.au/forums/topic/268544-turning-off-wtf/#findComment-4583596
