hey guys, going over the pits soon and car is going into workshop on Thursday...
i need a stock exhaust by then, only found out last night i need one, please someone help
i have an R34... do R33 exhausts fit?
please help, 6 pack in it for willing party, hope that's enough cheers!
Andrew
call me on 0433 560 364
https://www.sau.com.au/forums/topic/268585-stok-r34-exhaust/
yeah got a sticker...
had Guy's stockies on the rears and i was meant to change them that morning but i forgot the lock nut...
took Lucy home and got done for 'speeding' but they didn't give me a fine lol
gave me a sticker for tyres i was meant to change that morning!!! *steam coming out of ears*
another reason for the sticker is because my licence plate is on the wrong side like WTF... said nothing about the fixed back or anything in the engine or the ride height... is all good, car is going into the shop tomorrow
man i'm pissed off lol not long to go until the show either
reason for the liscence plate is i assume its on the drivers side?
If you get flashed the camera cant see it so your not allowed it like that.
They just don't like it being on that side, cameras still do pick it up anyway. Chances are the pits won't care about it being there anyway, even if the cop wrote it down.
camera can still see it no matter what side its on... they just dont like it... and why do you need to change your exhaust Andrew? Just raise it up a bit, get the 100mm clearance and your laughing man!
lol hey guys
thanks for all the advice, what's going to happen is i'm going to the pits to get an extension and only thing i'm going to fix is the cat
then i'll just fix the list they write down after i get my inspection because apparently i'll only have to fix that and not the WHOLE thing so yeah i'll take it from there
thanks for all the advice once again peeps as well as the offers for exhausts... i'll keep you all updated!!!
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
