Hi all,
I have researched this subject a little on SAU forum (the only one I use) but would still like some advice please.
By the way thanks to all who helped me with advice on my clutch....I went to Hyperdrive and got an Exedy HD organic and love it!!!!
I now want to increase power a little.
At the mo my R33 S2 has approx 170rwkw
Intercooler, pod with cold air intake and box, big fuel pump, manual boost up to 10-11lb, 3" cat back.
The next thing will be front/dump pipe........After reading here I will probably go with Kermit for a 3" bell mouth .......good idea????
Anyway, my question really is what to do next...and I mean soon.
I got blown off by one of those G6E turbos ...LOL
I am thinking of hi flowing standard turbo and getting some ECU upgrade. But this is where it gets a bit fuzzy.
I want to keep it as simple as poss.
Therefore the hi flow route.
I want approx 220-230rwkw.
I want 1 bar boost.
I don't want to have to do any more mods than I already have (except front pipe)
I don't want to spend $1000+ on PFC and $500 on every tune.
I would like to keep my budget down to approx $500-$1000 for complete ECU/ECU upgrade and tune.
I see my options as a Mines ECU, piggy back setup (too many to choose), R32 ECU chipped.
Any help would be much appreciated.
https://www.sau.com.au/forums/topic/268589-i-want-more-power/
Don't have much to offer except re: ECU..
You can actually pick up brand new PowerFC's from the states for a hell of a lot less than people in Aus try to sell theirs for second hand.. Not sure if they're still being produced, but there was a slow 'on-demand' supply of them late last year.
AUD to the USD is picking up slightly and if it gets better it'd be worth looking in to if you'd consider spending a little more.. I got one for about $800AUD delivered..
hE DUDE i got an r34 4 dr with a R33 S2 highflow,
Basicly same mods as you but have Full zaust (decat)
Apexi SAFC and re tune,
Got around 300 hp at the rear on 10 psi and shit sparks can easy get 350 which plenty for the street!
Get the Front Dump If you got the Money 110% PFC and good sparks / injectors and get a tune,
Even a Cam for bottom end tourqe ?
Good Luck!
High flow turbo costs $2000.
Then u will need bigger injectors and fuel pump. An ECU would be best. Like Apexi Power FC or Wolf 3D.
A R33 can't have its ecu remaped like a R32. So a SAFC or piggy back ecu would be cheaper, but not worth it.
Check forced induction section to see what mods people have for what power.
BTW, a G6E has a 4L turbo engine making ~300kw. A stock R33 makes ~187kw. My R32 with RB25DET made 220rwkw on a stock turbo, bigger fuel pump and with a WOLF 3D ecu.
Oh ans search in the right section, don't just slap any random question in the WA section. This topic is covered every week.
G6E / xr6T makes 270kw
Barra 4.0L DOHC DI-VCT TURBO I6
(270 kW 533 nm)
* XR6 Turbo
* G6E Turbo
If you do your front/dump & cat next, then get an SAFC2/neo and a tune, you should be at around 200rwkw. That's around 275kw at the flywheel.
Given the R33 GTS-T is around 350-400kg lighter then a Ford G6E, you should be able to beat one, no?
(that's assuming the G6E is stock...)
Edited by dnbosiris
Oh yeh, sorry. The F6 is 310kw. The old F6 is 270kw. The old XR6T is 240kw, new one is 270kw.
I reckon thats awesome.
So a G6E turbo = 270kw for 1800kg. similar to R33 + mods = 220kw for 1400kg. 220rwhp
Then it depends on traction etc. or if its a roll on, torque etc.
1) why?
2) if the answer is to beat x time or x car that does x time then the power is just a means to an end and it's not the only one. whatever power is needed to win is all that matters. However much power that happens to be is not the point.
Edited by rev210
any idea of who does a hiflow service in Perth ? They replace with steel wheels when doing this right?
Is it really that expensive?? At $2000 couldnt you buy something heaps better?
thanks for all the replies
do hiflows cost $2000??
OK so I def will go Garrett / HKS turbo
still unsure about which ECU
will check out US suppliers now for POWER FC
also found a bit about VI-PEC ecu
$2000 but supposed to be the best performer and easiest to tune
given up on Mines etc and piggy backs
what about R32 ECU with a chip???......anyone had experience
Come on I want to beat that crappy falcon
P.S I am calling Kermit tomorrow re front/dump and cat
yOU CAN Find highflow cheaper these days
I was lucky to get a new one of my mate for $500
all i did is a Bosh500p in tank fuel pump
SAFC APEXI
better sparks + the mods mention up top
New turbo
Means - New Injectors / mainfold / mounts ect could work out for $$ but better in the long run!
turbo & components - recommend gt3076r 0.82 housing (get from mtq)
injectors - sard 850cc injectors (get from slide)
ecu - recommend vipec (get from auto worx)
fuel pump - recommend bosch 044 (get from a forum sponsor)
z32 afm - get from slide
thats probably going to cost around 6-7k installed. recommend compression test & leak down test to check engine health.
ViPec? I wouldn't go there. Most people get PFC's andother full aftermarket ECU's 1000+
Semi ones like piggy backs etc. Common are Nistune on R32 ecu's (not for 33) or E-manage or SAFC II. 500+
Yeah, u can get HKS or Garret turbo kits's for 3000$. Do it
Mines ecu's don't come tunable, I don't think. Or next to no-one in perth tunes them. You have limits on ECU's etc u have coz there might be tuners with little to no experience with a certain one.
MTQ, Turbotec and P3rf0m4anz turbo's or whater ever do it in Perth.
Or order a Highflo from GCG turbo's. One of the best hiflo companies in AUS.
But yeah, there are also other ways to beat a car in a race. Better tyres, better brakes, smaller wheels/tyres (diameter) = quick acceleration, lower diff ratios, more weight over rear wheels for better traction of the line, but if rolling start race, then less weight.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
