fletch63 Posted May 5, 2009 Share Posted May 5, 2009 Hi all, I have researched this subject a little on SAU forum (the only one I use) but would still like some advice please. By the way thanks to all who helped me with advice on my clutch....I went to Hyperdrive and got an Exedy HD organic and love it!!!! I now want to increase power a little. At the mo my R33 S2 has approx 170rwkw Intercooler, pod with cold air intake and box, big fuel pump, manual boost up to 10-11lb, 3" cat back. The next thing will be front/dump pipe........After reading here I will probably go with Kermit for a 3" bell mouth .......good idea???? Anyway, my question really is what to do next...and I mean soon. I got blown off by one of those G6E turbos ...LOL I am thinking of hi flowing standard turbo and getting some ECU upgrade. But this is where it gets a bit fuzzy. I want to keep it as simple as poss. Therefore the hi flow route. I want approx 220-230rwkw. I want 1 bar boost. I don't want to have to do any more mods than I already have (except front pipe) I don't want to spend $1000+ on PFC and $500 on every tune. I would like to keep my budget down to approx $500-$1000 for complete ECU/ECU upgrade and tune. I see my options as a Mines ECU, piggy back setup (too many to choose), R32 ECU chipped. Any help would be much appreciated. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/ Share on other sites More sharing options...
NA_Goodness Posted May 6, 2009 Share Posted May 6, 2009 My S2 R33 has high flowed turbo with Trust internals and a remapped factory ECU. Not sure the cost, but it's cheaper then a PFC or ViPec. I'll be upgrading in a few months if you want to buy it off me. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4577068 Share on other sites More sharing options...
bryno Posted May 6, 2009 Share Posted May 6, 2009 Don't have much to offer except re: ECU.. You can actually pick up brand new PowerFC's from the states for a hell of a lot less than people in Aus try to sell theirs for second hand.. Not sure if they're still being produced, but there was a slow 'on-demand' supply of them late last year. AUD to the USD is picking up slightly and if it gets better it'd be worth looking in to if you'd consider spending a little more.. I got one for about $800AUD delivered.. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4577526 Share on other sites More sharing options...
bubba Posted May 6, 2009 Share Posted May 6, 2009 My remap cost me $880 (pre-Nistune days). As for hiflow turbos.. aren't they like $2k? fair enough they bolt on but I'd rather go for a Garrett item. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4577751 Share on other sites More sharing options...
BANGN Posted May 6, 2009 Share Posted May 6, 2009 rule of thumb when you buy a R33, first mod - dont waste your money on SAFC's turbos and boost controllers.. get your self a new ECU, they allways run rich and underpowered on the factory ecu. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4577768 Share on other sites More sharing options...
RICCA Posted May 6, 2009 Share Posted May 6, 2009 hE DUDE i got an r34 4 dr with a R33 S2 highflow, Basicly same mods as you but have Full zaust (decat) Apexi SAFC and re tune, Got around 300 hp at the rear on 10 psi and shit sparks can easy get 350 which plenty for the street! Get the Front Dump If you got the Money 110% PFC and good sparks / injectors and get a tune, Even a Cam for bottom end tourqe ? Good Luck! Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4577777 Share on other sites More sharing options...
lunjiaow Posted May 6, 2009 Share Posted May 6, 2009 Maybe a GT3076R, 044 Fuel Pump, Standard or Aftermarket ECU to get 350hp? Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578325 Share on other sites More sharing options...
reNEGaDe88 Posted May 6, 2009 Share Posted May 6, 2009 High flow turbo costs $2000. Then u will need bigger injectors and fuel pump. An ECU would be best. Like Apexi Power FC or Wolf 3D. A R33 can't have its ecu remaped like a R32. So a SAFC or piggy back ecu would be cheaper, but not worth it. Check forced induction section to see what mods people have for what power. BTW, a G6E has a 4L turbo engine making ~300kw. A stock R33 makes ~187kw. My R32 with RB25DET made 220rwkw on a stock turbo, bigger fuel pump and with a WOLF 3D ecu. Oh ans search in the right section, don't just slap any random question in the WA section. This topic is covered every week. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578362 Share on other sites More sharing options...
dnbosiris Posted May 6, 2009 Share Posted May 6, 2009 (edited) G6E / xr6T makes 270kw Barra 4.0L DOHC DI-VCT TURBO I6 (270 kW 533 nm) * XR6 Turbo * G6E Turbo If you do your front/dump & cat next, then get an SAFC2/neo and a tune, you should be at around 200rwkw. That's around 275kw at the flywheel. Given the R33 GTS-T is around 350-400kg lighter then a Ford G6E, you should be able to beat one, no? (that's assuming the G6E is stock...) Edited May 6, 2009 by dnbosiris Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578447 Share on other sites More sharing options...
reNEGaDe88 Posted May 6, 2009 Share Posted May 6, 2009 Oh yeh, sorry. The F6 is 310kw. The old F6 is 270kw. The old XR6T is 240kw, new one is 270kw. I reckon thats awesome. So a G6E turbo = 270kw for 1800kg. similar to R33 + mods = 220kw for 1400kg. 220rwhp Then it depends on traction etc. or if its a roll on, torque etc. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578640 Share on other sites More sharing options...
rev210 Posted May 6, 2009 Share Posted May 6, 2009 (edited) 1) why? 2) if the answer is to beat x time or x car that does x time then the power is just a means to an end and it's not the only one. whatever power is needed to win is all that matters. However much power that happens to be is not the point. Edited May 6, 2009 by rev210 Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578696 Share on other sites More sharing options...
urtwhistle Posted May 6, 2009 Share Posted May 6, 2009 i think the key is torque and gob fulls of it. the bara will destroy a stock turboed 33/34 esp with a rolling start Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578699 Share on other sites More sharing options...
errno Posted May 6, 2009 Share Posted May 6, 2009 High flow turbo costs $2000.Then u will need bigger injectors and fuel pump. An ECU would be best. Like Apexi Power FC or Wolf 3D. A R33 can't have its ecu remaped like a R32. So a SAFC or piggy back ecu would be cheaper, but not worth it. Check forced induction section to see what mods people have for what power. BTW, a G6E has a 4L turbo engine making ~300kw. A stock R33 makes ~187kw. My R32 with RB25DET made 220rwkw on a stock turbo, bigger fuel pump and with a WOLF 3D ecu. Oh ans search in the right section, don't just slap any random question in the WA section. This topic is covered every week. any idea of who does a hiflow service in Perth ? They replace with steel wheels when doing this right? Is it really that expensive?? At $2000 couldnt you buy something heaps better? Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578701 Share on other sites More sharing options...
fletch63 Posted May 6, 2009 Author Share Posted May 6, 2009 any idea of who does a hiflow service in Perth ? They replace with steel wheels when doing this right?Is it really that expensive?? At $2000 couldnt you buy something heaps better? thanks for all the replies do hiflows cost $2000?? OK so I def will go Garrett / HKS turbo still unsure about which ECU will check out US suppliers now for POWER FC also found a bit about VI-PEC ecu $2000 but supposed to be the best performer and easiest to tune given up on Mines etc and piggy backs what about R32 ECU with a chip???......anyone had experience Come on I want to beat that crappy falcon P.S I am calling Kermit tomorrow re front/dump and cat Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578734 Share on other sites More sharing options...
Char Posted May 6, 2009 Share Posted May 6, 2009 50/150 HP wet NOS kit $800 purge kit $200 bottle warmer $200 Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4578819 Share on other sites More sharing options...
RICCA Posted May 7, 2009 Share Posted May 7, 2009 yOU CAN Find highflow cheaper these days I was lucky to get a new one of my mate for $500 all i did is a Bosh500p in tank fuel pump SAFC APEXI better sparks + the mods mention up top New turbo Means - New Injectors / mainfold / mounts ect could work out for $$ but better in the long run! Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4579155 Share on other sites More sharing options...
bubba Posted May 7, 2009 Share Posted May 7, 2009 Don't need a new manifold or mounts.. and my stag is making 240awkw on stock injectors. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4579178 Share on other sites More sharing options...
Pattygtst Posted May 7, 2009 Share Posted May 7, 2009 turbo & components - recommend gt3076r 0.82 housing (get from mtq) injectors - sard 850cc injectors (get from slide) ecu - recommend vipec (get from auto worx) fuel pump - recommend bosch 044 (get from a forum sponsor) z32 afm - get from slide thats probably going to cost around 6-7k installed. recommend compression test & leak down test to check engine health. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4579361 Share on other sites More sharing options...
reNEGaDe88 Posted May 7, 2009 Share Posted May 7, 2009 ViPec? I wouldn't go there. Most people get PFC's andother full aftermarket ECU's 1000+ Semi ones like piggy backs etc. Common are Nistune on R32 ecu's (not for 33) or E-manage or SAFC II. 500+ Yeah, u can get HKS or Garret turbo kits's for 3000$. Do it Mines ecu's don't come tunable, I don't think. Or next to no-one in perth tunes them. You have limits on ECU's etc u have coz there might be tuners with little to no experience with a certain one. MTQ, Turbotec and P3rf0m4anz turbo's or whater ever do it in Perth. Or order a Highflo from GCG turbo's. One of the best hiflo companies in AUS. But yeah, there are also other ways to beat a car in a race. Better tyres, better brakes, smaller wheels/tyres (diameter) = quick acceleration, lower diff ratios, more weight over rear wheels for better traction of the line, but if rolling start race, then less weight. Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4580532 Share on other sites More sharing options...
dnbosiris Posted May 7, 2009 Share Posted May 7, 2009 Come on I want to beat that crappy falcon OK say you get up over 200rwkw and can beat a stock XR6T what are you gonna do when one of those 6.2L LS3 HSV's comes along with 317kw... Link to comment https://www.sau.com.au/forums/topic/268589-i-want-more-power/#findComment-4580549 Share on other sites More sharing options...
