But those LS3 Clubby's weight 1800kg+. with 317Kw and more torque than a telemarketer.
Power to weight is 170kw per tonne.
So a R33 with 1400kg would need 250kw, =~250rwhp. Which is double. Just traction issues for both. More for 33.
yeah but wikipedia and red book says this stat and that stat and blah blah blah lol, power is a question of money, someone will always be faster.
a budget u've set of like $500-$1000 on a basically stock R33 isnt gonna get u far.
once u start upgrading things on ur car, its like pringles once u pop u cant stop.
Well PFC's are discontinued. Great ECU's. But they are expensive 2nd hand and new from overseas. The wolf 3d v500 has huge capabilities and parameters. Top racing has been tuning them for ages. The ECU may have been average a few years ago, but that would have been V2 or V3 not V500.
The ecu's are Plugin Kits for Nissan R32,R33 GTST for $2,095. More people have gotten exposure to them in the last few years. So, its ur call.
your forgetting 317kw at the flywheel.
so thats ~240kw atw considering 25% drivetrain loss.
However the torque is alot more in an LS3 than your 25 thats for sure.
Were u talking to me? 250kw at the flywheel is around 250hp at the rears, with tha 25% drivetrain loss's, and the conversion from HP to kW.
Oh yeap, my mistake didnt see what you did there.
Converting from kw to hp half way through the post threw me off :down:
I'm more confused than ever now
If I may can I refine my original question now I have more info.
I reckon alot of guys have to me in my situation
I have a car that goes pretty quick
I just want it to go a bit quicker
I am sure I don't want an all out race car
just this one mod will do
I have about 180rwkw and want to go to 220-230 AND THAT WOULD BE IT !!!
I know it has to be a turbo upgrade and so an ECU upgrade (my stock ceramic is at its limit ...10-11lbs)
What can I do for $1500
will a piggy-back do if I am absolutely sure there will be NO MORE MODS
I have the exhuast, the intake and the FMIC
I know I won't need injectors for this HP (have the in tank 500HP pump tho)
I really don't want to go the dyno/tuning route if I don't have to....is this poss???....with piggy-back maybe????
But I will do it if I have to (maybe once!!!)
Pls help someone
Pls help someone
Why 220-230rwkw?
If all you want is a dyno readout then photoshop one.
On the other hand you can squeeze more 'go' out of your car but, sometimes there are compromises.
Tell us what it is you like about the car and exactly (as best you can) describe what you want the car to 'do' better. Set an actual goal.
This lessens the dollar waste and increases satisfaction because you have a design plan, not some half assed thought.
Why 220-230rwkw?
I don't want a dyno readout at all !
As I said I don't even want to dyno my car
I like everything about how the 33 drives (my first turbo)
It is fast and I love the way it drives now
But I want that extra bit of grunt
Maybe 60-70 horses....just pull harder..a nice turbo hit and then pull hard
No burnouts or crap...
Does that answer your question????
SECONDED!!
that site is a friggin good no-nonsense resource..
but in short
a) as someone already said how are you gonna know how much power you will have unless you get it dyno'ed
b) if you highflow your turbo and increase the boost then the ecu is more than likely going to make the engine run rich so you're going to need some sort of ECU piggyback or replacement combined with a dyno tune to correct this.
Edited by dnbosiris
get the biggest drop in injectors you possibly can around 740cc with a bosch o44 and a nismo fuel reg with a good computer and u can run 15 psi into your stock turbo and push just a tad over 300rwhp alot of people will say its not possible and not safe but it has been done
Good.
Your budget is too small for a start.
You like the nature of a fairly stock car and why not.
Getting the extra power is however something that doesn't say why 60-70hp is the magic number.
Why 60-70hp? Well you could upgrade the car to give you this amount of addtional power without really impacting the way the car drives too badly.
A new 2530 sized turbo would do this and with minimal difference in lag. Assuming you also take care of the tyres and suspension setup you can stick the extra power down to the road better.
You will ideally want an upgraded ecu and fuel pump and a beefier clutch friction plate (the stock pressure plate pressure is quite fine).
That will keep everything you like about the car but, up the power and straight line speed.
You want to be making use of that on a track by the way for full benifit. :P
Edited by rev210
overkill for 300hp?
standard turbo will be out of puff before the injectors
and 15psi is to much
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
