Hi, I have an R34 and Im thinking of putting a 6x9 speaker in the rear. My question is will it fit at the back without using a spacer? Is there anyone out there put a 6x9 speaker on their R34. Will a 6x9 fit in rear without cutting the parcel shelf as we know that it is illegal. I planning to buy a 6X9 pioneer speaker.
https://www.sau.com.au/forums/topic/268599-help-about-rear-speaker/
It is not possible with out either cutting the shelf which is a no no... or cutting the grills and spacer which will look terrible...
also make sure you can put your child restraints back or you might get yellowed and never pass the pits without them.
I have done my stereo stealth and sounds sweet for very little $$.
dont get pioneer!!! that is all....
also yea get 6.5" and get a sub for the bass use the 6.5 only as rear fillers if you dont have people sitting in the back dont get rears!!!
My pioneers fit fine..... with the orig covers. Def go the sub!
Don't know if this helps, but the 6x9s fit well in an R33, new parcel shelf, fitted right out on the edges on top of the rear struts gives just enough room for the magnet....no cutting of the metal required.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
