Entry Form - http://www.wrx.com.au/motorsport/WRX_Sando..._Entry_Form.pdf
Supp Regs - http://www.wrx.com.au/motorsport/WRX_Sando...e_Supp_Regs.pdf
Check your entry has been received - Entry List - http://www.wrx.com.au/forum/viewtopic.php?f=23&t=57498
2009 SAU Vic Motorsport Championship proudly sponsored by:-
https://www.sau.com.au/forums/topic/268629-sandown-sun-28-june/
  • Replies 143
Posted Images
just looking at the form, there is a tick box for entry fee and one for driver training.
does that mean if you want driver training it's an extra $145 ontop of the $185? or you have to tick one or the other and if you tick driver training, it's a slightly restricted day?
EDIT: i should read everything first...
"5. Driver Training Group
“Driver Training Group” sessions are a separate group in this event and Drivers participate only in this
group and pay the reduced entry fee.
For this component of the event, the following will apply to all drivers:
• There will be a separate Novice Group briefing and attendance of all drivers participating in this
component is mandatory.
• the club will provide a Driving Advisor / Instructor for each Driver
• Overtaking is not expected or encouraged in the ordinary course of this component of the event. If
overtaking is required it must be done in a safe and cautious manner. Those drivers who overtake in a
dangerous manner will be reported immediately to the Clerk Of Course and subject to penalties (which
can include exclusion from the event). Those drivers who are being overtaken must indicate by
pointing to the side they wish to be overtaken and maintain their line. The responsibility for the
overtaking manoeuvre rests with the overtaking vehicle.
• Drivers who wish the Driver Advisor / Instructor to drive their vehicle in this component do so
entirely at their own risk."
Do we know who the instructors will be?
cheers
Nah, it's the cheaper option of the two.
thanks guys :D i should have read the pdf's more carefully :P
so is it cheaper because you get less track time? i take it you still get to participate in the timed events?
how would this compare to say the Driver Dynamics open pit days? Those days are instruction days as well but they're around $260
well the DD days have some pro drivers giving you indepth instructions.
these will ahve some people who know the track give you some tips..
so really depends on what you looking for
you will learn more from a DD day...but you pay more as well..
but won't get points in the club championship either!
M
M
cool, thanks for that mate
would you say track time is comparable between the DD days and these WRX ones?
Interested, would have been great if they were using an AASA permit, then I wouldn't have to buy a CAMS license :D
Probably time I should buy one....
So 4 * 8min runs even for the driver training group? And after say 3pm to 4pm its a little more open or....? Never been to a club track day.
I've done Sandown once with the driver dynamics group, and Winton during a fun day, but I'm only running some average street tyres and think the driver training might be a good idea...
Guest
