  • Replies 143
Posted Images
going on last meet, yes. though that was my first so....was a great day chasing down the wrx rookies :D
Interested, would have been great if they were using an AASA permit, then I wouldn't have to buy a CAMS license ;)
Probably time I should buy one....
So 4 * 8min runs even for the driver training group? And after say 3pm to 4pm its a little more open or....? Never been to a club track day.
I've done Sandown once with the driver dynamics group, and Winton during a fun day, but I'm only running some average street tyres and think the driver training might be a good idea...
No they will not do licenses on the day - you will need to organise it beforehand.
You have plenty of time to get it sorted out, so shouldnt be a problem.
A word of advice though, dont leave it till the last minute - these things do take a little time to organise.
You'll also need to make sure your SAU Vic membership card is up to date.
Sent off CAMS registration today via mail, faxed off the driver training entry form to the WRX club and organised the $$$.
Anyone else doing driver training?
Didn't want to slow more experienced members down on the track :)
Can anyone enlighten me on the "in Victoria" bit of the section of the Supp Regs quoted below ? I'm thinking of coming down from NSW, am a member of two CAMS affiliated clubs in NSW, and hold an L2S licence with one of those clubs. Surely I don't need to join a Victorian club as well ?
I emailed the "motorsport" address listed on the website of the WRX club a fortnight ago with the same question but haven't yet received a reply.
All drivers must hold a current CAMS Level 2S licence or higher and be a financial member of a Club
affiliated with CAMS in Victoria.
Looks like im going to have to miss this one too :P
Exam on the Monday :huh:
My exams are thankfully over by then. Hopefully it's not raining so we get a decent day like the last one. By the end of it I'd cooked my brakes because of nearly 40 laps of punishment.
I queried this on your behalf and was given the below response:
I thought Colleen had covered this!! Obviously not.
As long as he has a L2S Licence and proof of his affiliation then I am sweet with it.
J
Didn't want to slow more experienced members down on the track :D
Hey mate
I'll be dragging the R33 out for it's first run on the track and doing the driver training as I'm a noob!
Glad to hear I'm not the only one... Are you running an R33 also? What mods have you done?
Mine is stock turbo and ECU pulling 200+rwkw and I'm keen to see how it goes up against other R33/34s.
See ya there
Hey mate
See ya there
R33 GTR, as per my sig, don't want to high-jack the discussion with my car specs/mods/et cetera
The WRX thread on this is here no entry list yet :D
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
    • @PranK, why do we have this restriction? Because photos are the first thing that gets asked of new people on the forums. Do the spam bots post photos if allowed?
    • How do you rate the clutch @joshuaho96? Sometimes I wonder whether it's genuinely very driveable or whether I just feel that way because it cost a good chunk of money. Most recently when seeing the guy at the tyre shop struggle to move the car...
