Thanks for the replies and comments guys, please keep them coming we are open to all suggestions and ideas, but 'the buzz' as mentioned we were there for only half a day, so we did unfortunately miss quite a few cars, but i think the range we did get was good. Thanks for your comment :)
  • 1 month later...
  • Replies 143
Posted Images
cleaning out my camera yesterday i stumbled across a few shots i took at sandown a couple of months back...
Thanks for the pics, great shots - have saved them all for my desktop at work... :devil:
Regards
Andrew
Guest
