hi guys,
im about to drop my engine back into my gtr - 26/30 build which means that my intercooler plumbing which runs to the intake plenum on the drivers & passenger side will ‘more than likely’ not marry up due to the difference in height @ 38mm (taller rb30 block).
I have an idea to cut my factory black rubber pipes somewhere in the middle, then add a similar diameter alloy pipe which would be 2inches in length to run inside the rubber pipes, fixed with 2 strong ‘t clamps’ – I can then adjust the length to suit!
What other ideas are out there which also work? It would be great if I could get silicone aftermarket intercooler pipes to suit the additional length :)
i was also advised to elongate the engine mount holes by 5mm so that the total height drop to about 33mm
don't mess around just get alloy pipe. if you pick up standard hard pipes the plenum side really just needs 38mm extra added in the middle and the turbo side needs a little bit of fiddling but any fabricator worth their weight can do it.
hi guys, dont think anyone on this site has mentioned this yet, if the rb26/30 is going in a 33 then get a 32 hard pipe hks etc, its a straight fit no alterations, the 32 hard pipe from wing-plenum is 38 mm taller than a 33 one. this only works fitting a 30 in a 33 shell bernie uk.
p.s i know i have done it..
bernie,
i have an r32gtr :-(
http://www.skylinesaustralia.com/forums/Rb....html&st=40
post 57 and post 59
No change to the intercooler plumbing either. But I used silicone joiners, maybe they were a little longer.
As previously mentioned, you will have to redrill the lower bell housing bolts, but that's a 5 minute job.
I didn't lengthen the dumps either, but they weren't standard ones.
I upgraded the sump (Performance Metalcraft) for GTR oil surge prevention.
Plus added an oil cooler, of course.
I also extended ther lower cam cover, so it met up with the standard RB26 top cover (keeps the rocks out)]
mmmmm my mistake though, thought he used the standard pipes
thanks steve - you're a legend for finding this :)
this answers my question that silicone joiners will work if long enough - perfect info :)
can anyone tell me what the outside diameter of the intercooler hoses are?
~80 mm
But I find 3" (76.2mm) ID silicone hose works OK, stick it in some hot water and it stretches easily..
That gives an OD of the silicone hose of ~90mm, although some silicone hoses are bit thicker.
Cheers
Gary
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
