Does anyone know what the OEM Super DOT 4 "Special" fluid for R35 is? I need to carry fluid to the track, so thought i would pick up a bottle. The dealership want about $180 for a litre. Now i know i can just flush the whole system out with Motul 600 or something, but for the moment i just want to bleed the calipers after a track day.
Anyone know?
Edited by LSX-438
https://www.sau.com.au/forums/topic/268669-oem-r35-brake-fluid/
Duncan
I tried to Pm you but for some reason it won't let me, it's not just dot 4, it has a lower viscosity (spell) for the VDC system, if you replace it you "might" have an issue with the VDC. Maybe someone who has actually used a race style dot 4 could give you an idea it would cause an issue.
  • 9 months later...
Duncan
We've had one guy come in at work who bleed his system with non gen fluid and was having vdc issues. If your getting pre/post track checks from your nhpc they'll bleed them then, otherwise I havent heard/seen any non gen fluids around yet.
funny you should mention the VDC light though
bleed brakes last weekend with AP600.
the VDC light popped on for me momentarily at one stage of turning on and off but have driven all week without any issues and no more warnings
any good qual dot 4 will mix with it fine. any of the 600degree dot 4s will be good. RBF600, AP600 etc. all fine.
actually....I've tried all the top line brake fluids and got best results from the motul rbf600. the best thing about it is that it is about $30 a bottle from motor bike shops.
I have used ap 600, caltex (dark horse!), motul rbf600, brembo whateveritwas, agip. motul 600 performed best.
  • 1 month later...
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
