I installed a 3inch cat back the other weekend. After the install i did an ecu reset but the car still runs real sluggish.
It felt a lot more responsive with the old restrictive exhaust on.
Can someone please give me some help?
Seems clear? :)
Bit wierd, if anything it should be making a tad more boost and run better.
Edited by gotRICE?
i just installed a 3" dump pipe and cat to go with the rest of my 3" exhaust using the standard ecu. car feels a tonne smoother throughout the whole rev range and air filter is heaps noisier below 3000rpm because of the increased flow and the turbo being able to spool up sooner. you should definitely not be feeling sluggish. not sure about diagnostic though.
Take your car for a quick test drive and look at the factory boost meter.
it should reach full boost at about 3000rpm.
it may sound silly, but check your exhaust manifold, you may have a leak.
Should come on bit sooner than that.. mine makes 10psi by 2700.
Although with full exhaust.. not just cat back.
mine doesn't make full boost, 10psi until 5,000 RPM. Is there a problem? Could 3.5" be causing back flow problems in my case?
Afaik, not a problem unless the actuator has been modded...
http://www.skylinesaustralia.com/forums/HO...ost-t42895.html
  • 2 months later...
Strange... Turbo car likes a freeflowing exhaust after the turbo.... engine gets its backpressure from the turbo.... Big exhaust in a N/A car and you don't have enough backpressure + exhaust speeds are too low and it'll work against you. Correct? (very simplified obviously)
I bought my GTS-T with a 3.5" catback on it, got it switched to a stocky for EPA test and it felt so restricted.... bout the same low down, but high range and it struggled.
Not correct.
Most people with N/A's put exhausts on and don't tune.
I had a twin 2.25" exhaust on a V8 years ago - loved it
i would check the dump pipe. when removing or installing the new exhaust you may have twisted the dump pipe a bit (possibly when trying to undo the bolts on the cat) and it may be causing the wastegate flap to foul slightly and not close properly.
definately a problem. i had a 3.5" exhaust with stock ecu and was making 12psi by under 3000rpm. may be an issue with your boost controller (i also had an issue with a boost controller causing boost to come on very late. it wasn't releasing the pressure between the controller and the wastegate when you lifted off so when you changed gears the wastegate would still be open, and on a few occasions it was open so far at 5000rpm i was only just starting to make boost)
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
