dose any one have tips getting an hcr32gtst past epa
convered all back to standerd
excepet spit fire coils
10psi actuator
3inc cat back
frount mount and piping
no bov
standard ecu( insted of mines ecu)
standard fule press reg ( insted of sard ajustable )
still with walbro 440 fule pump
standard injectors
new plugs
new oil 0w40 castrol edge
standard turbo & manafold (insted of t51 high mount)
standard air box mounted on angle due to intercooler piping(removing washer bottel to fit)
NEED HELP
wont pass on idle
DBs ok got down to 89db
ARGGG
dont know what else to do
https://www.sau.com.au/forums/topic/268734-need-help/
10psi actuator
3inc cat back
no bov
standard injectors
new plugs
NEED HELP
wont pass on idle
ARGGG
A guy i know got busted for his zorst being too loud he put a plate with a smaller hole between the flange on the cat it passed
https://www.sau.com.au/forums/topic/268734-need-help/#findComment-4580419
  • 1 month later...
exhaust is now fine
still wont pass!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
disconced varex canon did the trick
and yes it now has an adr aproved cat
all before i went for the test!!!!!!!!!!!!!!!!!!!!!!!!!
dose any one have a clue!!!!!!!!!!
Edited by Rits2.0tpig
https://www.sau.com.au/forums/topic/268734-need-help/#findComment-4645770
Haha I'll let you know RE the exhaust, girlfriend just got an EPA notice for her Datto ute being too loud, will probably try drilled out bits of metal between flanges since it apparently already has 2 mufflers :S. I have had a flange put after the last bend of my pipe so I can swap over a cannon if need be.
https://www.sau.com.au/forums/topic/268734-need-help/#findComment-4646251
    • New or used transmission? Alignment will be the same with engine running or not. If new, i'm presuming it's a clutch release bearing size issue. If used, are you certain it's a CD009/A and not an older CD008 or less? They had known synchro issues. In my opinion, these transmissions should always be purchased new, they're dirt cheap and you avoid dealing with old revisions.
    • I like your thinking! Looking forward to see how it turns out.
    • You've got yourself a good old game of have fun. That shit is annoying as hell to remove. Thankfully for you, yours is on metal, most of the stuff I take it off is plastic, so typically hear guns are out. I normally end up continually dragging my thumb with pressure over it to get it to peel up. Eucalyptus oil then works well for getting residue and last remnants off.   Edit: plastic scraper might be worth while too. One that'll dig into the foam tape, but not scratch the paint.
    • So I ride and race motorcycles for fun and have always used a van to transport my track weapons. Figured towing a racebike with a skyline would be different and if done right could - "look fully sik" or quite cool for us grown ups lol. Pic of yours truly on two wheels I also have a trailer already kitted out to transport my bikes ...and I have a spare set of rims that match the car that I was going to rebarrel to get deeper dish at some stage but they have just been gathering dust. Sooooooo it is only logical.... Stay tuned !!
    • If by "flap disc" you meant "chocolate wheel".... then they are OK for getting off stubborn remnants. But not for stuff with bulk depth. If by "flap disc" you meant "abrasive paint f**ker"....
