nuff with the hating...isnt the whole point of these forums to figure things out???
thanks for the sugestions tho
Only way to shut it up is by putting on the standard air box (good for 250rwkw) and factory return bov(good for near on 20psi).
And yes we are here to help, much like the other 20 million threads you would have found on this subject if you had done a search on it.
Just the poddy sucking in air.
You'll still get a bit of turbo spool and if ur reading the stock boost guage it reads in negative and positive pressure.
Anything below 0 is vaccum pressure and above 0 is boost pressure. So even if you apply only a small amount of throttle your still increasing vaccum pressure = more air being sucked in = louder noise
