Hi, I am having trouble picking a cooler for my R34 GT-T. I currently have a GTR front mount but have decided not to use it and just buy a kit. I'll be running a Power FC, AVC'r, full turbo back exhaust, either a HKS 2530 or 2540 turbine and am looking for between 220-250 rwkw. Any ideas please. Thanks :D
  • Replies 52
I plan the same mods as you for my 33, PFC & 2530.
Currently have a full 3" exhaust, and went with the Trust VSPL kit (600/276/75). I'm aiming for a responsive street car.
Have you checked out the locally made Hybrids 600/300/65 $1400? Allot of people will recommend them.
https://secure-krakatoa.commercevault.com/p...r/index_01.html
I have a greddy/trust RSPL kit. hasn't provided any restriction yet. and no noticable pressure drop. Intake temp remains max 5 degrees above ambient. Took about 2 hours to install and the power difference was immediately noticable. The 440rwkw GTST from JMS Runs a 4inch thick trust cooler. Apex ones look funky...haven't had much experience with them.
HKS Type-S for a R34 GT-T plumbs back under the cooler to the original pipes. Thats why I want one, stuff going over the engine bay. You can buy a HKS upgrade kit for the rest of the pipes worth about $800-$900.
Check it out for yourself at: -
http://www.pbase.com/franks/07dec02_fmic_i..._install&page=1
(Thanks to Franks for that one, legend!)
As far as I know on the R33's they flow over the engine bay.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
