  • Replies 52
Hi I fitted a Blitz to my R34 and it works a treat.The pipes plumb back into the original holes it does not go over the top of the fan.
A bit of cutting on the front bar but other then that pretty easy to install.
Got mine from Auto Barn as they are the agents now for Blitz.
Originally posted by Sydneykid
Hi Adzmax, we have found standard R34 GTR intercoolers good up to 300 rwkw.  Cheaper and far more durable than other alternatives.
Yeah but GT-R coolers lack the BLiNG you get from a big HKS or Trust unit.
Oh and ARC coolers look like truck units... unpolished and not too impressive looking.
T.
Ok just got off the phone then and was told R34's are a pain in the arse to fit coolers in and I'd be looking at about $700 for pipes and fitting. Thats going over the engine too! so $1400, same price as a HKS cooler BUT it is already fitted for that price I guess. Hmmmm Decesions decesions.....
Adzmax we fitted the cooler in about 4 hours there is a bit of mucking about.
Main problem is the metal brace across the grill that has to be cut a little to fit the cooler.But if you have an angle grinder it is no problem.Also the front bumper has to be cut back slightly ,but I supose it depends on the type you have on your car.
All in all a pretty simple fit.
Just purchased the complete Blitz Cooler kit and away we went,took about 4 hours,we did not rush the job.
The piping connects directly back to the original piping.
Where are you located?
  • 8 months later...
Decided to dig this old thread up just to say thanks for all the help!
I decided on an ARC cooler kit, Installed it myself and I must say it's a really sweet design. Very small amount of cutting to be done and pipe work is very neat as the pics show!
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
