Did some upgrades on my car and now don't need these parts.
  • White faced dash cluster = $200
  • Note: One of the tags broken of clear plastic cover, other than that in very good condition.
  • Factory coil packs = $200
  • Factory Injectors = $250
  • Factory fuel pump = $100
  • Pioneer Head Unit = $100
  • Genuine R34 Factory rear bar = $140
  • Factory cam gears = $30
  • Turbosmart dual stage boost contoller = $100
  • New Supra boss kit = $40
https://www.sau.com.au/forums/topic/268784-32-gtr-parts/
what condition are the injectors in? can i flow test them before i buy? im a serious buyer btw. pm me please
My injectors were working perfectly when I had them pulled out to upgrade to sard 700cc injectors. I can get them flow tested if you like, but it will put the price up on the injectors depending on the price for flow testing. Your choice.
Cheers,
Sid
https://www.sau.com.au/forums/topic/268784-32-gtr-parts/#findComment-4588870
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
