hey,
I have a 93 r32 skyline and ever since i have bought the car about a month ago when i am sitting at idol the Revs fluctuate up and down around 100 -300 revs, also misfires occasionally
i have only really noticed this when its just sitting and idol and will get worse if i leave the car to idol for long periods
it does not do this when the engine is cold and the choke is on, it really only happens when the car is warm/hot
i have recently replaced the air flow meter, oxygen sensor and had the TPS (Throttle position sensor) adjusted
If anyone knows of wat could be making my car do this or have any suggestions don't hesitate to Post
cheers
  Duff_man said:
is that like the iacv valve?, would the fix the misfire as well?
Yes the Iac valve will fix ur hunting idle..the misfire would be a coil pack issue
  Duff_man said:
ok. yeah but if the misfire was a coil pack, it would continue as i rev up the engine wouldnt it?
Yes it does both, my car used to misfire at idle like mofo, and up above 500rpms, after i changed the spark plugs to platinums and changed the coils, it ran beautifully..But if u gonna change the coil packs,have the taped up or covered in silicon gel so no spark escapes from little hair line cracks. Either that or get splitfire coils and u wont regret it
chrrrz
Ben
Are you running an aftermarket ECU? I had idle hunting problems running power FC base maps on numerous RB engines.
Otherwise I would be cleaning out your ICU and changing sparks, check the coils and leads too see how they look as well.
nah standard ecu. cheers, yeah i'm thinkin it could be the leads to coil packs, i have read other people's posts with similar problems and they were talking about CAS, wat is CAS? and if it is this how can i check
Yeah,,check the ignition leads and look for a vacuum leak too,,might just be that
CAS = Crank Angle Sensor...Its silver and sits on the front of the motor on the exhaust cam.
ICU is not the name...Its AAC valve = Auxilary Air Control Valve. It is located at the rear of the plenum and looks like an alloy block with a small can on it. Has connector plugged into it.
I'd suggest you clean out your AAC valve first and go from there. Theres a guide on how to do it on here somewhere. Have a search and you will find it.
  • 3 weeks later...
if u disconnect the plug on the AAC wat will happen to the car while its running? my idle is all over the place, and when i clutch in too quick at the lights it stalls
other problem is the car is running way too rich.. the back bumper is always black??
wat to do?
the AAC valve only controls the engine idle when you turn the air con etc on and the IAC or idle air control valve does the idle if i am not mistaken?
clean them out and check for vac leaks even a tiny hole in your intercooler can screw the AFR and this will make it run heaps rich and idle like a bitch.
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
