Gday all
When pulling up to a set of lights i have a noise that sounds like a pump of some kind, Its not to loud but i am guessing that its not supposed to be there.
You can only hear the noise when pulling up and about half a second after coming to a complete stop the noise will stop, But if you slow right down
to less then walking speed it will still be there no matter how far you roll, The noise doesn't change speed or volume and it doesn't change if its in neutral or clutch in, Could it just be a noisy Attessa pump?
any ideas would be good
I had this posted in drive train and transmission and got no answers,
https://www.sau.com.au/forums/topic/268893-noisy-attessa/
As far as i understand the attessa pump isnt running all the time? Only when it needs to be? If it is running though will only be at a small output?
Normally if you get into the car, turn the car "on" but not start it you can hear the pump start, build pressure then stop.
I maybe wrong but thats my impression?
If thats the case then it shouldnt be what your hearing?
https://www.sau.com.au/forums/topic/268893-noisy-attessa/#findComment-4580676
I have checked the rear reservoir and when idling its a little over min
The noisy isn't there when idling or when first taking off just when coming to a stop and rolling to a stop, very strange sounds like a cheap fuel
pump
I assumed it was the attessa pump because i am sure its working all the time (well guessig) i don't know to much about the whole attessa system
its very strange and starting to get annoying not louder just annoying!!!
https://www.sau.com.au/forums/topic/268893-noisy-attessa/#findComment-4580763
That was my impression too.
Start the car first thing in the morning and walk straight to the drivers side rear wheel, you will here the ATTESA pump building up pressure in the system.
Is that the same sound you described?
Edited by iamhe77
https://www.sau.com.au/forums/topic/268893-noisy-attessa/#findComment-4581584
Try bleeding it - 2 bleed points one on end of gearbox extension nr hose and one on top of diff - and if the fluid looks crappy change it with a good quality atf. (BTW if it comes to it i have all the atessa stuff spare - atessa ecu and the stuff that sits on top of the diff).
https://www.sau.com.au/forums/topic/268893-noisy-attessa/#findComment-4582262
thanks for all your help, I know nothing about the attessa system i dont even know where the attessa ecu is and didnt know where the pump
was until 2 seconds ago, , I might try and have a look tomorrow
cheers
Edited by Punk72
https://www.sau.com.au/forums/topic/268893-noisy-attessa/#findComment-4583069
For your reading :) Theres a number of different system types but this is the one the Stagea uses.
ATTESA-ETS
The Electronic Torque Split version off this all-wheel drive architecture was developed for usage in Nissan's north-south layout vehicles, and was first used in August 1989 in the R32 Nissan Skyline GT-R and Nissan Skyline GTS4. It utilizes what is mostly a conventional RWD gearbox. Although the Skyline GT-R is exclusively AWD, ATTESA-ETS is also used in Nissan models that are also available as RWD such as the A31 Nissan Cefiro which was the second Nissan to feature the system exactly a year later in August 1990. Drive to the rear wheels is constant via a tailshaft and rear differential, however drive to the front wheels is more complex by utilizing a transfer case at the rear of the gearbox. The drive for the front wheels comes from a transfer case bolted on the end of an almost traditional RWD transmission although the (bell housing is slightly different to allow the driveshaft for the front wheels to pass it, the main body is exactly the same as the RWD transmission, the tail-shaft is different to couple to the transfer case). A short driveshaft for the front wheels exits the transfer case on the right side. Inside the transfer case a chain drives a multi-plate wet clutch pack, torque is apportioned using a clutch pack center differential, similar to the type employed in the Steyr-Daimler-Puch system in the Porsche 959. On the rear differential is a high pressure electric oil pump, this pump pressurises Normal ATF oil (0-288psi) into the transfercase to engage the clutchpack. The higher the oil pressure the transfer case is supplied with, the more the clutch pack engages, this is how the torque to the front wheels is varied. The transfer case has its own dedicated ATF (Nissan special ATF) oil to lubricate the chain/clutch pack. The front driveshaft runs along the right side of the transmission, into a differential located on the right of the engine's oilpan. The front right axle is shorter than the left, as the differential is closer to the right wheel. The front left axle runs through the engine's sump to the left wheel.
The ATTESA-ETS layout is more advanced than the ATTESA system, and uses a 16bit microprocessor that monitors the cars movements at 100 times per second to sense traction loss by measuring the speed of each wheel via the ABS sensors. A three axis G-Sensor mounted underneath the center console feed lateral and longitudinal inputs into an ECU, which controls both the ATTESA-ETS 4WD system and the ABS system. The ECU can then direct up to and including 50% of the power to the front wheels. When slip is detected on one of the rear wheels (rear wheels turn 5% or more than the front wheels), the system directs torque to the front wheels which run a viscous LSD. Rather than locking the AWD in all the time or having a system that is "all or nothing", the ATTESA-ETS system can apportion different ratios of torque to the front wheels as it sees fit. This provides the driver with an AWD vehicle that performs like a rear wheel drive vehicle in perfect conditions and can recover control when conditions aren't as perfect. The advantage to a more traditional ATTESA (Viscous LSD) system is response in hundredths of a second.
ATTESA E-TS system is used in the following models:
· R32 and R33 (1989-1997) GTS4 Skyline
· GT-R - 1989–2003
· Nissan Stagea
· A31 Cefiro
· Infiniti G35x/Nissan Skyline (V35 & V36)
· Infiniti FX
· Infiniti EX35 (with Active Brake Limited Split for side-to-side torque split, as needed)
· Nissan Fuga (Known as Infiniti M in export markets)
· Nissan GTI-R
https://www.sau.com.au/forums/topic/268893-noisy-attessa/#findComment-4583626
  • 1 year later...
  • 5 years later...
I know this is an old post but I have exactly the same problem and just wondering if anyone knows what this annoying pump sound might be? It is exactly as the OP described.
I have just bled the attessa system and it did not stop the noise. As soon as i started bleeding it i knew it was not the same pump sound.
I dont think it is the fuel pump because it seems to be linked to wheel speed. If you are rolling slowly it will keep running until i come to a complete stop. Then it will stop completely until i start moving again. Car is a stagea C34 RS4S factory manual. Hope someone can help!
https://www.sau.com.au/forums/topic/268893-noisy-attessa/#findComment-7751760
  • 3 months later...
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
