Originally posted by rob77
It helps to do a search before asking. Try ross @ perth autoclutch in osborne park. About $830 drive in and out for a 2500pound pressure plate 9 puck clutch doing me well and I have a touch under 350hp @ wheels.
thanks for the replies guys
i did a search under 'clutch' but go fed up after the first 6 pages and though starting a post would be easier.
whats drivability like with a clutch like that rob77.
anyone get one that was a little cheaper than $830??
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568659
Got one of Ross's clutches in the R.
So far survived 2 sessions at the Plex with 7k launches!
Feels like an OEM clutch is installed, however.
I'm not kidding myself that it will last forever, however if it lasts me a year, I'm still ahead of buying a $3k twin plate (that I doubt will last 3 years!)
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568707
Add me to the list of happy ross @ autoclutch customers. I went the 9 puck ceramic plate with 2500lb pressure plate. A little harder to push down and a bit different to get used to but once you do you'll love it.
I've got approx 260rwhp and it copes with it fine. It's lasted 2 drift days - kicking the clutch in second at 5000rpm, shown in avitar :P - and didn't miss a beat. No shudder or light pedal feel afterwards.
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568751
mine is an Exedy brass button...cost me 800 to put in..
good for arnd 450hp according to Evo R which is where i did it
drives well...after u get used to it...a tad bit heavier than the stocko but like i said, works well after u get used to it...and bites like a fkin piranha too
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568914
I got a brass button clutch in my car (from the previous owner) installed by XSpeed and I was told it cost about $900. Not sure what brand it is, but I don't really think its the best clutch out there.
My brass button (like all other brass buttons I think?) has no 'ride' whatsoever i.e. you can't ride the clutch, say, if you want to balance the car on an upward sloping hill. You can do it for about 2 seconds before you hear this shrill grating metal-on-metal screech (that sounds like running your nails down a chalkboard). I guess thats the 'brass' in my clutch.
The clutch is either on or off, so it sucks when you're in traffic, especially if the road is going uphill. Plus riding the clutch gently when in reverse is not possible without the screech. But if I release my clutch fully in reverse the car hoons along backwards - not the best thing in carparks :rofl:
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568969
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
