Originally posted by rob77
It helps to do a search before asking. Try ross @ perth autoclutch in osborne park. About $830 drive in and out for a 2500pound pressure plate 9 puck clutch doing me well and I have a touch under 350hp @ wheels.
thanks for the replies guys
i did a search under 'clutch' but go fed up after the first 6 pages and though starting a post would be easier.
whats drivability like with a clutch like that rob77.
anyone get one that was a little cheaper than $830??
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568659
Got one of Ross's clutches in the R.
So far survived 2 sessions at the Plex with 7k launches!
Feels like an OEM clutch is installed, however.
I'm not kidding myself that it will last forever, however if it lasts me a year, I'm still ahead of buying a $3k twin plate (that I doubt will last 3 years!)
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568707
Add me to the list of happy ross @ autoclutch customers. I went the 9 puck ceramic plate with 2500lb pressure plate. A little harder to push down and a bit different to get used to but once you do you'll love it.
I've got approx 260rwhp and it copes with it fine. It's lasted 2 drift days - kicking the clutch in second at 5000rpm, shown in avitar :P - and didn't miss a beat. No shudder or light pedal feel afterwards.
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568751
mine is an Exedy brass button...cost me 800 to put in..
good for arnd 450hp according to Evo R which is where i did it
drives well...after u get used to it...a tad bit heavier than the stocko but like i said, works well after u get used to it...and bites like a fkin piranha too
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568914
I got a brass button clutch in my car (from the previous owner) installed by XSpeed and I was told it cost about $900. Not sure what brand it is, but I don't really think its the best clutch out there.
My brass button (like all other brass buttons I think?) has no 'ride' whatsoever i.e. you can't ride the clutch, say, if you want to balance the car on an upward sloping hill. You can do it for about 2 seconds before you hear this shrill grating metal-on-metal screech (that sounds like running your nails down a chalkboard). I guess thats the 'brass' in my clutch.
The clutch is either on or off, so it sucks when you're in traffic, especially if the road is going uphill. Plus riding the clutch gently when in reverse is not possible without the screech. But if I release my clutch fully in reverse the car hoons along backwards - not the best thing in carparks :rofl:
https://www.sau.com.au/forums/topic/26907-clutch/#findComment-568969
