I don't know anything about the GTR driveline but I can imagine the front wheels smoking the hell out of the tune shop lol overheard someone saying you can pull a relay out or something for rear wheel drive only but I dunno about how truthful that is, seems a little silly to me but as above I've no idea if the front an rears can seperate 100% to stop it launching out the front door :D
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4582950
P.S. Rav i apologise for my sarcastic post :D my imagination just got the better of me ;) I would assume they would be very comparable as the output of the motor will be the same just depends how well the driveline holds up running 4 or 2 wheels. I wouldnt imagine too much difference
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583022
Just asking because i made 297kw on a rw drive Dyno, And some guy was giving me Sh*t saying there no way i made that power with stock AFM's and if i put it on a 4wd Dyno it be way lower out put.
So i thought i would post up and ask if this is true.
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583087
Power has nothing to do with AFM's.
If you max the afm you can still tune for peak power. Just means there's a point when its ramping up on to boost where its a little rich and missing a little ignition timing as that 'load point' is tuned expecting more airflow which requires more fuel and less ignition.
Edited by TheRogue
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583149
Well he clearly doesn't know what he's talking about
So don't listen to him :D
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583162
Thanks guys for the info, It was pretty funny because i only meet this person for few mins and we fighting over how much the stock AFM's can handle and my tuner dyno is so happy.(I know thats not true so many people get a lower rideing on it then any other dyno).
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583175
Man i hate those guys... think they know it all and u dont even know them from a bar of soap, yet they are apparently the fountain of knowledge about YOUR car... I just laugh at them these days like these guys don't know crap... normally makes them madder and you win :)
I have a GTS4 and I always thought it was about 20-30kw less on a 4wd dyno?
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583199
You cant just pull the fuse out in a R34 GTR to go to RWD like with the R32s
I think in a R34 there is ~10% difference. Ie: 300AWKW is 330RWKW
Anyone done both in an R34??
You can pull a fuse out in a 34 , i have , its just highly unrecommended ... I done a test .
Power On RWD 17PSI = 335 REAR WHEEL KWS
Power On 4WD 17PSI = 310 REAR WHEEL KWS
Not much of a difference , Seems to be right .
Edited by MRGTR911
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583832
Don't pull the fuse on the R33/R34, the clutch packs there is a pre-load on the transfer case, see the above post...
Its fine to do it in an R32 because they don't use this pre-load...
I've read this, but is the pre-load applied electronically or mechanically?
I have an R32 gearbox/transfer case in an R33 GT-R.
Does this mean that the transfer case still has a pre-load applied to it by the ATTESSA computer, or is there no pre-load because its an R32 transfer case?
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4586639
There will be a difference between 2WD and 4WD readings on a dyno...
Its simple physics..In 4WD mode you have an extra driveline (minus g/box) running the front wheels. The transfer case, prop shaft, front diff and front drive shafts all exhibit frictional loss and therefore when they are moving, consume power. When they are not moving (2WD mode) they are not consuming power. There is also a fair amount of power loss between the tyres and the dyno rollers...So an extra pair of tyres spinning an extra two rollers...you guessed it more friction.
So there WILL be a difference between 2WD and 4WD mode on a Dyno...I would guess around 10-15%...
On the road however it is a completely different story... the front driveline is either being rotated by the transfer case (when torque is being directed to the front) or in 2WD mode, by the road itself turning the front wheels. Irrespective of what is turning what, the front driveline is rotating so it is still consuming power.
So in my mind looking at GTR dyno figures in 2WD mode and comparing to RWD figures is not a useful comparison because it is not considering 100% of the driveline loss. Even with a RWD on a dyno you are neglecting to measure the loss from the front wheels and bearings as well.
It all gets down to what do you really want to find out...If you want to know how quick your car really is take it to the strip..If you like seeing big (slightly exaggerated) HP numbers on a screen, put it in 2WD mode and take it to the dyno... If you are looking for a simple correlation between the 2, stop looking because it is not as simple as that. (PS I know you weren't asking this but I know it will come up...)
cheers
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4586796
bugger all because a GTR isnt fulltime 4WD, nor is it a 50/50 split like a WRX/EVO
The guy (he is THE GTR tuner) who does your dynoing does the same we do and simulate the small extra load, . That way they pull the same whether it be 4wd or 2wd.
Edited by URAS
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4587784
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
