I don't know anything about the GTR driveline but I can imagine the front wheels smoking the hell out of the tune shop lol overheard someone saying you can pull a relay out or something for rear wheel drive only but I dunno about how truthful that is, seems a little silly to me but as above I've no idea if the front an rears can seperate 100% to stop it launching out the front door :D
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4582950
P.S. Rav i apologise for my sarcastic post :D my imagination just got the better of me ;) I would assume they would be very comparable as the output of the motor will be the same just depends how well the driveline holds up running 4 or 2 wheels. I wouldnt imagine too much difference
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583022
Just asking because i made 297kw on a rw drive Dyno, And some guy was giving me Sh*t saying there no way i made that power with stock AFM's and if i put it on a 4wd Dyno it be way lower out put.
So i thought i would post up and ask if this is true.
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583087
Power has nothing to do with AFM's.
If you max the afm you can still tune for peak power. Just means there's a point when its ramping up on to boost where its a little rich and missing a little ignition timing as that 'load point' is tuned expecting more airflow which requires more fuel and less ignition.
Edited by TheRogue
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583149
Well he clearly doesn't know what he's talking about
So don't listen to him :D
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583162
Thanks guys for the info, It was pretty funny because i only meet this person for few mins and we fighting over how much the stock AFM's can handle and my tuner dyno is so happy.(I know thats not true so many people get a lower rideing on it then any other dyno).
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583175
Man i hate those guys... think they know it all and u dont even know them from a bar of soap, yet they are apparently the fountain of knowledge about YOUR car... I just laugh at them these days like these guys don't know crap... normally makes them madder and you win :)
I have a GTS4 and I always thought it was about 20-30kw less on a 4wd dyno?
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583199
You cant just pull the fuse out in a R34 GTR to go to RWD like with the R32s
I think in a R34 there is ~10% difference. Ie: 300AWKW is 330RWKW
Anyone done both in an R34??
You can pull a fuse out in a 34 , i have , its just highly unrecommended ... I done a test .
Power On RWD 17PSI = 335 REAR WHEEL KWS
Power On 4WD 17PSI = 310 REAR WHEEL KWS
Not much of a difference , Seems to be right .
Edited by MRGTR911
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4583832
Don't pull the fuse on the R33/R34, the clutch packs there is a pre-load on the transfer case, see the above post...
Its fine to do it in an R32 because they don't use this pre-load...
I've read this, but is the pre-load applied electronically or mechanically?
I have an R32 gearbox/transfer case in an R33 GT-R.
Does this mean that the transfer case still has a pre-load applied to it by the ATTESSA computer, or is there no pre-load because its an R32 transfer case?
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4586639
There will be a difference between 2WD and 4WD readings on a dyno...
Its simple physics..In 4WD mode you have an extra driveline (minus g/box) running the front wheels. The transfer case, prop shaft, front diff and front drive shafts all exhibit frictional loss and therefore when they are moving, consume power. When they are not moving (2WD mode) they are not consuming power. There is also a fair amount of power loss between the tyres and the dyno rollers...So an extra pair of tyres spinning an extra two rollers...you guessed it more friction.
So there WILL be a difference between 2WD and 4WD mode on a Dyno...I would guess around 10-15%...
On the road however it is a completely different story... the front driveline is either being rotated by the transfer case (when torque is being directed to the front) or in 2WD mode, by the road itself turning the front wheels. Irrespective of what is turning what, the front driveline is rotating so it is still consuming power.
So in my mind looking at GTR dyno figures in 2WD mode and comparing to RWD figures is not a useful comparison because it is not considering 100% of the driveline loss. Even with a RWD on a dyno you are neglecting to measure the loss from the front wheels and bearings as well.
It all gets down to what do you really want to find out...If you want to know how quick your car really is take it to the strip..If you like seeing big (slightly exaggerated) HP numbers on a screen, put it in 2WD mode and take it to the dyno... If you are looking for a simple correlation between the 2, stop looking because it is not as simple as that. (PS I know you weren't asking this but I know it will come up...)
cheers
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4586796
bugger all because a GTR isnt fulltime 4WD, nor is it a 50/50 split like a WRX/EVO
The guy (he is THE GTR tuner) who does your dynoing does the same we do and simulate the small extra load, . That way they pull the same whether it be 4wd or 2wd.
Edited by URAS
https://www.sau.com.au/forums/topic/269077-dyno-reading/#findComment-4587784
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
