have finally got a GTST ECU in my GTS+t, idle is lumpy tho, and still doesnt feel like its going as hard as it could...question is is it because the GTS AFM is the wrong one suited to a GTST ECU? have run the GTS ECU for a couple of months and havnt had any issues with idle etc, had heaps of low-down power, seem to have lost this when i put the T ECU in....
ideas?
https://www.sau.com.au/forums/topic/269078-gts-vs-gtst-afm/
  • 3 weeks later...
hey mate,
my car still has the NA afm, i was never too sure that there was a difference between turbo and non turbo, but i know that series 1 are green label and series 2 are pink,
i think that a tune or a remap should solve some of those issues,
and also make sure you have the correct Gtst ecu for your car, because if you have a series 2 you cant run a series 1 ecu as there is a difference with the ignition module or something, id double check your turbo ecu,
https://www.sau.com.au/forums/topic/269078-gts-vs-gtst-afm/#findComment-4626185
hey mate,
yeah man i hear you with the S1/2 ECU. i know for a fact that with a S2 ECU, the fuel pump doesnt even prime. are RB25 ECUs able to be remapped? what have you done to yours J3TR33?
https://www.sau.com.au/forums/topic/269078-gts-vs-gtst-afm/#findComment-4626195
bump: wanna sort this issue out before it gets too far down the track...
one thing iv noticed is that when the car is given a boot in the morning (usually atleast 5-10minutes after starting) it doesnt pop/splutter, or in other words ping. at all, when pushed above 4.5k rpm. i only did this a couple of times to test the theory that maybe once its at normal temp (past the stage of using the automatic choke) the ECU leans out the fuel mixture too much once it hits 4.5k.
if i can track down a GTST ECU and confirm that they are indeed different and talk to the ECU differently, hopefully its gonna start me on the road to solving these problems, along with a retune of the ECU (if thats possible, i dont really want to go down the road of aftermarket ECUs considering im running stock gear)
could it be anything else though?
also going to track down a bosch 040 to be on the safe side.
https://www.sau.com.au/forums/topic/269078-gts-vs-gtst-afm/#findComment-4627991
s1 and s2 ecu's are interchangable. they will both work in the same car. the ignition module is not part of the ecu therefore cannot affect how it runs. saying that it makes a difference is basically like saying altezza taillights will make your brakes stop working.
https://www.sau.com.au/forums/topic/269078-gts-vs-gtst-afm/#findComment-4628453
hey GODZLR,
i bought an ecu and a remap from toshi of the forums, it was a mail send out, because when i did the turbo conversion i had a series 1.5 ecu in my car and he only accepts direct changeover of ecu's if going the mail out option, i would highly recommend the remap from toshi, i am running 12psi with standard turbo and usual mods on my de+t and the power is awesome, very responsive, the remap and a shift kit was the best bang for buck, it solved most of my problems, but had to buy splitfires as my ones were stuffed, i ended up making 177rwkw on a hub dyno with the standard dump, i think if i change to an aftermarket dump and added some more timing i would be in the 180s mark, which is not bad considering its a conversion and auto, good luck with it but i would highly recommend a remap or aftermarket ecu and tune + splitfires if your coilpacks are dying,
https://www.sau.com.au/forums/topic/269078-gts-vs-gtst-afm/#findComment-4629182
hmm...food for thought. what fuel pump are you running?
organised a mate of mine to do the timing once i get hold of an AFM (hes got a turbo one so we'l see if it makes any diff) hes done mine before when it was still NA and man it made a diff, so hopefully hel work it again :ermm: but will keep your suggestion in mind. how much did it set you back?
https://www.sau.com.au/forums/topic/269078-gts-vs-gtst-afm/#findComment-4630101
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
