We had a pretty phenomenal RB30 in last night, the brainchild of a good customer. This is a daily driver, home build and complete credit to the guy. A quick look at the results and im sure you will be astounded at how qiuckly it makes boost and how broad the power and torque curve are... i have NEVER seen any 6 cylinder pull within a 1/3rd of the low end torque this thing does (no gas). On the road this car will fry the tyres in 3rd from 3000rpm..... with only a stab on the throttle boost is instantanious.
Any one care to guess what the secret is?
Edited by URAS
  • Replies 43
Posted Images
oh just for interest here is an identical (minus the polariser) setup GT3540 rb30 for comparison
Reference numbers on bottom of graph are set to show difference in power and torque @ 3000rpm
Torque 268nm vs 532nm ! This torque is more than most rb25 and 26's make @ peak :D
Power 84rwkw vs 167nm !
Edited by URAS
No semi slicks.... :D .....and based on your comments of instaneous boost......I'd say....twin scroll and also judging by the shape of the curve i.e. virtually no discernable difference in the curve between boost and off boost and linear power delivery over a broad rev range.
Edited by juggernaut1
X2 for spool valve. or possibly something like an eaton M90....?
haha yeah, toyota charger run by the haltech via NOS control (load rpm etc) then via a differential valve into the cooler, when the turbo boost exceeds the charger boost it is business as usual.... of course everything is also compounding so boost builds very quick. The charger drag seems to rob about 10-12rwkw from the top end. A few hours on the dyno and the boost switching/ load point is almost impossible to pick which was a big suprise for both of us.
The graph above of the the 2 rb30's is actually the same car before and after.
I have NEVER been in a car that builds boost and torque so rapidly other than BIG dollar supercharged v8's, its a real credit to luke.
Edited by URAS
Sounds like quite a tricky setup...and much better than trying to ram the turbos boost through the little toyota blower.
Do you have any photos of the setup?
It really does sound like a Sequential Turbo Supercharger Setup.
Have you thought about using an aircon clutch on the blower snout like the Castlemaine Rod shop setups for v6 commodores. so you're not losing power by running the blower after the turbo takes over?
it has, thats what the NOS control on the haltech is taking care of.... in 3d... not just running off a rpm or boost switch.
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
