Well i'm in the process of fitting a 26 in a C35 an getting some problems to pipe the stock blow offs back to the intake.
The OEM plastic cannot work because of the two 4" pipes i have for my CAI so i was thinking of using one greddy recirculating valve with some sort of 1" flexible hose back to the intake
The stock pipe where the stock blow offs come back into one is 2" and i just dont have space to run such a big flexible hose back to the intake either, not to mention i cant even get a flexible enough hose in that diameter to buy.
So my question is..... Why Gtrs use two blow offs even though they come back in to one commom pipe back to the intake?!?
And will it be a problem if i use one greddy recirculating valve(attached) instead???
Any help ASAP will be greatly appreciated
https://www.sau.com.au/forums/topic/269156-gtr-blow-off-valves/
i believe bovs come from both sides of inercooler. to allow pressure to be released from inlet and outlet side of intercooler.
Possibly to create a more uniformly distrubuted release of pressure through your intake system? correct me if im wrong.
Ok
Ill be running stock turbos at 13-14psi. I was just wondering if this valve would be able to discharge the volume of air necessary to have the system working properly.
I noticed when i had this valve on the 25 it made the fluttering sound when releasing from small throttle openings....Was this compressor surge,or is it just the way these valves work?
Probably have to do something with the adjustment?
Thanks again.
yes you are wrong. both BOVs are mounted on a common pipe that is attached the outlet pipe of the intercooler. and then they have another Y pipe that joins their outlets and feeds it back to the intake.
you can use one, but that BOV will flow much less air than the factory set-up. why not just use the factory twins? they are good. otherwise if you wan Greddy use the type R. it's a much better unit than the cheap type S one you have pictured.
2x turbos = 2x airflow = 2x BOVs ...why they didnt just make one bigger one i dont know
but if your using those type s ones use two. ive seen them on the same pipe the stock ones are on so there are adapters to suit. (they sound stupid too just like the hks ones)
go a type R... i run one and they are good... dont go pssshhh or kaching... just a big venting/dump of air sound
exactly. to be honest 1 type S will be much worse than stock, and even two Type S will be certainly no better than stock, and possibly worse as they have a very small valve.
either keep the stock ones which are great, or get the type R one which is actually good. if you just want BOV noise then get some pods and a alluminium hard pip kit. at least it's actually beneficial as well as noisy.
one thing you guys missed is where he has said this... The OEM plastic cannot work because of the ""two 4" pipes i have for my CAI""
anyone say overkill on the cai.. get rid of one of those 4" pipes and run your piping how it should be with 2 stock gtr bov's or a trust type R bov.
Well after some fiddling,cutting,grinding and the use of some colorful words i got the oem valves to work.
I used some 2" air breeder hose and changed one of my 4" cai pipes to a 3"
Cant even hear the blow offs talk to each other right now cause i'm driving with just the front pipe alone. :P
looks good mate. best choice you could have made. I ran them on my old 32 GTR which had a full built motor, with serious headwork, cams, HKS turbos, power FC, 700cc injectors etc etc the full works and the stock BOVs handled the 20 odd psi pumping through them no problem.
