Vi-pec Ecu?
JamesK
 Share
Ok I think i might have seen a thread or 2 of this product around the forums but the stupid - in the name makes it impossible to search just was wondering people's experiences with this ECU and I think the obvious question: is it worth over a PFC? (Please don't kill me Paul) just curious
Little research
Vi-PEC
V88 Model ECU
ViPEC fuel injection, and engine management systems, were developed for Ray Hall Turbo Pty Ltd to fill a gap in the market, for ECU that were reliable, powerful, easy to tune and having features that worked correctly. ViPEC is willing to listen to what the market wants, and is dedicated to giving customer excellent support.
ViPEC produces two engine management models, the V44 and V88. Also plugin ECU based on the V44 and V88 for Subaru, Mitsubishi, Nissan, Mazda and Toyota cars. All offer three dimensional mapping of fuel and ignition and are full sequential up to eight cylinder. Support for up to twelve cylinder wasted spark. Also a four channel twin capacitor CDI ignition.
ViPEC software has advanced tuning tools like QuickTune which enables hands free tuning with no input is required from the user other than running the engine through its various RPM and load sites. Features TuneAhead™ which tunes cell around the site being tuned.
Motorsport features like Antilag, Flatshift and Launch control are standard features on the V44, V88 and plugin ECU.
The V88 model has E-Throttle (Electronic Throttle Control). This was devloped using automotive industry standards, and ensures accurate and safe throttle control.
Peak and hold injector drivers on the V88 are 10 amp. Both the peak Amps and hold Amps can be set separately in the software for optimum injector control.
The engine management systems are well designed with special attention to resistance to interference from other engine components. Main processor is soldered to the ECU board and not in a socket. This ensures a high level of reliability. All models can be upgraded by downloading the latest firmware.
Marine versions of the V44 and V88 are available. These are not just in a sealed case like other make ECU. The whole case of the ViPEC ECU are filled with Silicon making them 100% water proof at all times. The V44 model is ideal for small water craft like JetSki's. The V88 for ski race boats.
I just searched "dirtgarage" and "ECU" found this New Plug-in Ecu Coming, Better than Power FC and aussie made, also turned up Vi-pec Ecu, One for the wagon!! and Guilt-toy Installs Vipec V44 Plug In..
I've read good things about it, I was considering going E85 + this ECU when I go aftermarket turbo's which is looking like a long long time away. lol
HEY! Hamish havent seen you in a while hows everything bro, should of came to Pizza, but I neeeeedd mooorree powweerr....mind picking me some E85 while your at it? haha
if you are going to consider a vipec
go for an autronic or motec unit instead
probably the same price, more tuners available and probably better product support
given its more mature
yeah youd be better off going for autronic smc for sure
these range of ecu's are really geared, feature wise, price wise for motorsport competition
sure you can use it in a mild street no problems, but typically the cost and features dont suit
ie its too expensive and you dont need remote telemetry to track what gear you are in
Speak to Trent @ Status Tuning, he's had a play with some, i think he had some good things to say about them as well.
But he can also tune all the other ECU's mentioned in this thread, so he could give you an unbiased opinion on which one would suit you.
Do you have a powerfc already?
hey mate. I've got a vipec ecu running my r32 GTR. Straight plug and play and im really happy with it. Wouldnt go anything else. Cold start is amazing, running 800cc injectors, big cams and doesn't miss a beat. Plenty of protection, fuel cut options, boost cut, boost control. Got 420kW at all 4 at 22psi. Lovin it. For more info call scott at insight motor sport in Sydney. Great tuner! Knows his shit
Edited by MAD R32 GTR !
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
