Hi guys,
Ok here is the problem, a couple of weeks ago i noticed when turning left or right, smtimes even when braking, and esp acceleration the speakers started cutting out, like all sound went to the Right smtimes to Left speaker then came back to normal....Now thou, it is permanantly stuck on the righ side....i tried changing the balance but when i change to full on left speaker there is hardly any sound.
Anyone have any ideas on this?...or could identify any key areas where the problem might be...the speaker connections or the headunit connections?
oh and just like to clarify that my Headunit is perfectly fine, like nothing wrong with CD changer or anything.
https://www.sau.com.au/forums/topic/269175-speakers-going-haywire/
clarify this fault - it happens when, under what rules, what source? radio and CD or CD only.
if so then it looks like you DO have a CD issue. it will drop an ENTIRE side. if you are losing it under both sources then the problem is still in the radio just in a different spot.
autosparky wont have a clue. unless you have the radio service manual ( I do) then you wont get a lot of help.
Chris,
ok, well NOW it happens continuously, i.e its been like this for days ( the sound being stuck on the right side speakers. )
...and reading your post i went out and checked, it only happens in CD mode, in RADIO mode it is fine...so CD ONLY.
hope it clarifies it.
Chris,
it does. I have a car in the workshop now with the same issue. I have to tear it down on monday and the 'fault' lies in the CD section (where it runs through 4 different paths.)
I can fix it anyway. looks like a good time to roll out the reworked/retuned radios that I have here.
can you play your CDs in your DVD player?
If so... I have just fixed your car.
Check or money order will do fine :)
umm, i dont have the option with the screen, so i only have the CD player.
umm ok, so this is definitely not a job in which you can tell me to "try this" and then 'try that' and it 'should be all good?'...because your in brisbane and im in sydney?....and what do u mean its a good time to roll out the radios?
nope - its all internal to the radio. I have a fellow that sent me one via reg post ( Hi Hillbilly) with the same issue. I'l going to do a service on that one whilst I have it.
in saying that I should probably knock up a chargeable jig (that way I get it back) so you have A/C and no radio.
if you want to pull the radio and send it to me (RADIO ONLY- NO PANEL!! ) I'll fix it for you.)
as for my comment I've been quietly working on 'new' radios for these both bose and non bose versions that tune correctly and display correctly - only issue is price as I literally rebuild the stacker at the same time. ( they are roughly a $750-800 radio.). these are the original radios recal'd and reworked.
Yep, have the same problem. Haven't fixed it yet, but it seems the cheapest solution is to work around it, with an Ipod adapter.
See post below:
http://www.skylinesaustralia.com/forums/Bo...mp;hl=prdreilly
thanks prdreilly, but i have a question, can you do the ipod connector thing on a NON-bose system?...i rmbr chris putting up a DIY for connecting an ipod...or was that on g35driver....but yeh can you?
bit of interesting info and I'm going to need chassis numbers to confirm.
the car have here has a PN2613E in it. those have an ENTIRELY different CD mech in them. this is in a may 2004 coupe.
the 2413/14 twins (bose/nonbose) have the same issue but its in a different spot. this one looks like a component issue.
those with the above problem can I grab chassis numbers please. that will tell me if yours is fixable or not.
Hi Chris,
i got the same issues i send you PM last week to get a quote
now my Car is 2004 Series 1 70th Anniversary coupe, Chassis number 6U9000CPV35507647
As for the Sydney guys...
here is a video on how to remove the head unit, so you can send to Chris....
http://www.infinitihelp.com/diy/gcoupe/pro...t_procedure.htm
I will be getting my DVD installed and Speaker Fixed Chris..just got to wait till 900 to arrive.... :P
Hi Chris,
My VIN is CPV35-508342.
I'm inclined to go for the IPOD option for cost reasons, but out of interest am happy for you to forward a quote.
Hi chris,
here is my Vin number : CVP35507357
could you also quote me on fixing the radio when sent to you?...and im also interested about that refurbished radio you are working on, just to clarify when you meant everything is displayed correctly does that also mean there is no need for the FM modulator anymore?
Hey Chris,
I haven't been using my Ipod for a while and this week when I started playing it in the car I noticed sound was only coming out of the right speakers. No sound from Left. Switched it back to CD and MD and its fine, both speakers work. Could it be a loose wiring caused when u pulled my center console apart few weeks back? This is in the blue car.
ok this is more FYI than anything else.
the issue seems to be with the PN2613/14 twins (13 being non bose.). unlike the 2413/14 versions (2001-2003) this thing is ENTIRELY different. that said if there is a CD mech issue in the 2613/14 - its a LOT easier to fix than the otehr one.
2413/14 - its a radio issue and not a CD one.
the dropped audio fault lies in the CD mech itself and requires a total strip of it. there are 4 boards in there and 3 places that the audio routes. on one there is usually a dry joint- its NOT a job for the beginner and unless you have a service manual I STRONGLY sugggest NOT attempting it.
Edited by Chris Rogers
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
