Hi Guys,
I know there is a BIG 'what is E manage' tread in this forum.
There is alot of helpful information in that thread, but I want to know if anyone here has one hooked up to a Skyline??
And what was the result and your experience??
Any issues with the firmware, software etc??
I know there is a newer version of the firmware (v1.36), but don't know exactly what is the difference from the old version.
Just want to know who has one running in their car and how it has perform.
Cheers
:P
https://www.sau.com.au/forums/topic/26918-e-manage-with-skyline/
  • Replies 44
I have a cousin who had just done that. Full E-manage suite. He's running .8 bar with a profec e01 which is part of the e-manage suite. Together with this he has the following mods:
trust fmic
hks dump pipe
hks 3" front pipe
high flow cat
3.5" hks hiper cat back
k&n panel filter (stock airbox)
tein ha adj coilovers
18" (235 at front, 265 at rear)
the car's gained an extra 30.5 kw at the wheels.
Any further details contact Peter from Advan at Silverwater.
Strutto, has anyone actually proved that the manual PFC is no good in an auto? I am running a modified manual ECU in my auto and am able to increase the boost to 1bar, although it wont hold until i fit an electronic boost controller. It also changes hard between gears and generally goes better with no real difference in fuel consumption. I have had no adverse effects except for occasional stalling but that was the case with the standard ECU.
Read this thread
Craz0 has tried it... Didn't work for him :(
4door_sleeper has it working :looney:
I haven't tried it... But if someone wants to lend me one I'll give it a go... :(
My theory is that the original Nissan ECUs "relay" information to the auto ecu whereas the powerfc's do not...
See that is why I went for piggy back instead of the PFC, car is auto. It is still not 100% certain that the PFC work with the auto ecu.
Craz0 mention it has worked but there is still some errors or bugs. Like the flashing of the power/snow switch.
Guys in the states has used an E-manage with a R34 (auto) and it was a success. More info can be found at the yahoo group - emanage. They got heaps of info there about the e-manage but not much on e-manage with skylines.
666DAN, you say the PFC can't be used in an auto can you tell me why?I just explained, I am running a Manual ECU in my auto and am having no problems, the auto has its own computer, the two talk to each other to limit the revs between gears and won"t allow any increase in boost over factory. Im sure that there is more to it than that, but no one i have talked to about it in a 12 month period has had anything more to say than put a 5 speed in it or you can't do it. ... There is no real difference between PFC and a standard manual ECU except the obvious ability to customise settings. Mind you my experience extends to 33's not 34's.
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
