  • Replies 44
I was lucky and brough it off a mate that just came back from oversea.
But even if you check out some of the internet sites, they are pretty cheap.
Now all I have to do is get the thing installed and keep all you guys posted. Hopefully I will be able to gain about 30kw and a better mid range torque with the ignition control.
Originally posted by AutoTrust
Strutto, has anyone actually proved that the manual PFC is no good in an auto? I am running a modified manual ECU in my auto and am able to increase the boost to 1bar, although it wont hold until i fit an electronic boost controller. It also changes hard between gears and generally goes better with no real difference in fuel consumption. I have had no adverse effects except for occasional stalling but that was the case with the standard ECU.
Have you run the Diagnostic on the Auto since you installed the other ECU? Does the gear changes fell harsh and does your auto hesitate to change up gears?
No i haven't run diagnostics, the only noticeable difference with gear changes is 1st to 2nd gear is brutal at WOT. No hesitation shifting up, however if i stuff around with the throttle to listen to the bov, it changes a little awkwardly, like a small free rev. This is characteristic of a trans that needs maintenance or is low on fluid. I will check this in the next 2 weeks as i am a lazy bastard!:( I do have a long term leak on the trans cooler that could be the culprit. when i get an EBC it will be less annoying swapping between the 2 ECU's as i have to adjust the boost for the stock ecu, therefore making it easier to check transmission behaviour with the auto and manual computers.
    • What are you planning to do specifically?  I would be very surprised if you need to learn any math for these 'few builds' you have planned for the future.
    • I transferred from full time service to Army Reserve, so I still have access, work has been super keen to get me in to work in the OPS realm, so just turning up to use the gym......and ovens, isn't causing any issues, apart from me needing to keep on telling them that I won't be doing any reserve days until I get my joint in Goulburn sorted  Basically I can now work whenever I want, for how long I want now, and it's all tax free Next time we have some fires or floods you might see me covered in mud, or cutting sick in some plant equipment cleaning up, the Reserves love getting in the news, LOL
    • Final finish outcome of 80°c was typical to the pics, I've turned the oven down to 50°c and will pick them up after the gym tomorrow  The before and after difference was amazing, the wrinkle paint has covered all of the casting marks completely It did take a couple of hours to key it all and get in all of the crevices, but, for me it was time well spent for the final outcome, but I have all the time in the world to do it at the moment  Ended up with 4 coats, each sprayed at different angles to get optimal coverage and thickness As for the fixtures and intake box thingo that hasn't made it, the supplier is apparently posting the fixtures, and, are now sending a different CAI that is in stock The replacement CAI is actually better than what I originally ordered, but will require a pod filter that locates under the front bar, still serviceable, but it basically removes the whole OEM filter box and ducts into the front bar, so filter cleaning will require ramps and the removal of some front bar undertray, not a war stopper, just some ramps and an additional 10 minutes work every few months From looking at it it is made from alloy pipe from the throttle body, through the CAI hole in the rad support, then right turning under the bar, luckily the wrinkle paint was on special and I got 2 cans for $30ish, so the alloy will get the same wrinkle treatment as the intake manifold, hopefully it turns up soon, either way, the car will be getting booked in soon, if the parts aren't here, I'll just get MX5 Mania to " make it work"
    • I'm so glad base security is so high. I see they stopped some random codger from being able to just wander in off the street... 😛   PS, intake looks good!
    • So far so good, another hour and their done
