Hi if i have put this in the wrong section pls move it. :D
Here goes i have a problem with my r32 gtst on a cold morning the car has no power it will boost fine but the revs are very slow to pick up and it kinda has a knock when i change out of first gear (gearbox is fine). at the same distance and when the car is warm it drives perfect. only happens when car is cold?
maybe o2 sensor, fuel pump?
only engine mods are: full hks exhaust
de cat pipe
pod filter
split fire coil packs
front mount intercooler
any suggestions would be great thanks?
https://www.sau.com.au/forums/topic/269198-r32-cold-morning-issue-help/
What grade oil do you run (10w-40, 15w-40, 20w-50 etc)? it might just be a simple thing of running an oil that has more favorable cold viscosity than the oil you use now (and guessing during summer as well)
Test the coolant temp sensor and test and clean the AFM
Coolant temp sensor should be around 3Kohms when stone cold and approx 300ohms when hot. If the sensor is faulty it will not be adding enough fuel for the cold start settings in the ECU.
hey thanks for the reply's
i am running 15w oil and have used 20w. have cleaned the afm but not tested it yet
where abouts is the coolant temp sensor located? (im new to skylines)
That's too heavy for a Skyline engine. And that is only the cold start viscosity - what is the other number?
A word of advice - DO NOT boost a cold engine. Wait until it has a bit of temperature.
IT'S NOT THE F****N O2 SENSOR!!!!!!!!!!!!!!!!
It's unlikely to be the water temp sensor - usually, when they fail, they don't tell the engine that it's up to temp, so the ECU overfuels the engine. Not a problem if the engine is still cold.
It's probably just that the ECU can't cope with the extra density of the colder winter air.
15w~ is not too heavy for an RB20.
And the coolant temp sensor is highly likely considering it pretty much handles the entire enrighment map by itself while the engine is warming up. They can fail the other way and the engine thinks it's warm so it doesn't add the fuel it needs for cold start.
Why would the ECU not be able to cope with the extra density of the colder winter air? No one else has any problems....or does he live in antarctica? That's what the AFM is for, it measures air temp and flow. It will compensate when the air is more dense or less dense.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
