I did a search and couldn't see anything on this.
My car is an R32 running HKS 2530 at 1.3 bar. I have a fairly choked exhaust with the stock dumps and front pipe. Power is basically unknown, it is pretty quick (I have a dyno of ~260awkw on the low reading mainline dyno in Canberra prior to replacing my cat). My car will come onto boost quite hard in 2nd and smoke the tyres up to high 7k rpm. Dramatic, but not the fastest way of forward movement. I drive like a Granny 98% of the time but I like to give it a hit now and then and wouldn't expect this in 2nd, nor is it especially legal. :P
I replaced the shit Nexens it had on it, with them the car would literally smoke all 4 at 100km/h. I figured it had to be the poor and balding tyres. I fitted 255/40/17 Toyo T1Rs to the TE37s all around which I've put several hundred kms on. It's slightly better but in second gear it's still hopeless, straight line is spins the wheels after 4500rpm.
Suspension is Bilstein shocks and unknown springs all around, with some changes to arms etc. as it came from Japan. The spring rates are of course stiff, but not overly so. The ride is quite compliant (certainly compared to a mate's WRX anyway). Camber is negative, but again nothing silly.
So my question is, WTF? How can a 4WD car with the same tyres struggle for grip when a mate's S8 RX7 (he runs a ported block + T04Z at 1.1 bar around 280rwkw) with the exact same tyres (basically the reason I bought them) have full grip?
Is there a certain set up that can cause this behaviour? It's got me beat. :)
https://www.sau.com.au/forums/topic/269209-tractions-issues-gtr/
Im betting its not spinning all four wheels, I think it'd only be spinning the rears and there is something wrong with your ATTESSA or more likely your transfer case.
The clouds of tyre smoke out the rear when held at throttle says otherwise... so definitely rears (ie. you are correct). You can feel when the front comes in as it progressively transfers and regains grip (perhaps 'all 4 wheels' was a touch of exaggeration but it certainly felt like that on the old tyres - but just more wheelspin). Perhaps that regain of grip was just natural and at all the 4WD aid... Thanks for the thought, I'll look into it. But something doesn't seem right. :)
Yeah,
I'd be checking your transfer case. Firstly, they are tough but one good run at power where the rears slip but front doesn't will toast the clutch packs in the transfer case.
Try this, put the car on a jack (trolly jack with wheels) up until rears are just off the ground. Then slowly give it a little clutch to see if the fronts can pull the car forward. When my transfer case was stuffed it couldn't pull the car forward at all.
Also check the smell of the transfer case fluid. If it smells burned then that is a bad sign. Like others said, bleed and check the attessa system.
I did the plates in my transfer case which was expensive. Might be better off just swapping the whole transmission as I've seen a few for sale on the forums.
Best of luck.
Good luck, if your transfer case was really, dead, the car becomes un-drivable, when my one died, I could release the clutch and the car would not stall (clutch had 1-2mm left on it, transfer case was broken).
Nah it's definitely working, in 2nd I'm getting 10kg/m which results in wheelspin. Whereas in 1st I get the full 50 which is no wheelspin (obviously less power in 1st too). I'll have a shop look at my suspension set up and then decide if I need a ATTESA controller.
The guage doesn't understand how shagged your attessa system may or may not be. It assumes it is working perfectly & displays how much front torque you would have if the system was working properly & the motoro was standard.
What frequently happens with Gt-Rs is the clutches in the attessa system wear. This causes the clearances in the system to become out of tolerance & you get a slow reacting system - ie more rear wheel torque than it should have. Given the system is old, slow to react & calibrated for a stock motor it is quite easy to end up where you are ie with a GTR driving like a GTST.
I meant it's definitely working not because of the gauge, but because jacked up in the rear only it lurches forward just by letting the clutch out at idle. It may be slower or not as strong, but it's definitely 4WD still. I'll resist spending a bomb rebuilding the transfer case for now.
You've been subjective with spring rates and camber in your post - what are the numbers?
Have you tried pineapples in the "traction" configuration? Although IIRC SK reackoned on 32 GTRs the "neutral" config was better, so maybe try both.
Its the transfer case. Testing without load means nothing.
Get it put onto a 4wd dyno with torque split monitoring and id almost bet my race car's transfer case that yours is shot.
They become slow and end up with rear wheel spin. Eventually when its really rooted it wont drive off the jack. But at the moment its only slipping under load.
We re-build our cases with specially designed clutch plates every 48hours or so of use as this exact problem starts to occur on the circuit. Mines doing it atm and needs to be rebuilt.
On the road with genuine parts your transfer should last a very long time. Its not as an expensive excersise as some people think and in my opinion ANY R32 GTR which has not had it done should have it done.
Sorry it's running some camber - unsure how much. Spring rates again unknown :D . As per Japan basically... ie. no idea LOL.
Pretty sure it's the transfer case, like Risking said just slipping under load. Rebuilt for under $1k I would be happy, cs! I'll struggle here for that I reckon.
I personally went down the path of second hand (R33 transfer case), and paid $400 for a second hand transfer case to be fitted, in my case I it wasn't the clutch pack that went, it was a shaft...
It's gotta be clutches in mine. So rebuilt is preferred.
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
