RB26 engine from r32 GTR. Bottom end needs a rebuild.
Head has been acid cleaned and checked in good condition.
Standard camshafts, coilpacks, water pump, injector resistor all included.
Also comes with throttle bodies and intake plenum of r34 GTR included.
Rocker covers painted in candy red.
RWD sump, properly welded up, no leaks. ** will sell this separately if someone wants it
or you can put a standard rb26 sump on.
* Also have a loom that will plug into an rb26 ECU, but will work with R34 GTT electrics, aircon, everything will work
$3900 ono
[email protected]
I want everything but dont have the dosh just yet. Why couldnt this be in 6 months time when my house is finished?? :P
Gonna put my built 26 into my 34 and put a stocker back into the stagea, everything i need!! bah.
I want everything but dont have the dosh just yet. Why couldnt this be in 6 months time when my house is finished?? :happy:
hi mate i know someone who may be interested but he only wants to spend $2500 and he wont need the loom, sorry if it seems like a low ball offer. are turbos included?
yeah sucks like that... oh well.
still for sale if anyone's after an RB26 with the RWD sump work already done! it's rare to find a rb26 head this complete with everything, including throttle bodies, coilpacks, etc.
Hey mate,
Might be intersted in the bottom end of the engine beacuse some people want the head
what needs to be rebuilt with the bottom end? looking for a block and crank
Let me know, im in melb as well
Cheers
Mike
$3900 ono
[email protected]
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
