For sale I have all parts purchased for my R33 GTS-T -most still brand new in packaging as unable to complete what i started -many regrets i must say -
1 x Apexi AVC-R Digital Boost Controller ( Limited Black with White LED display) Brand New still in box - $650.00
1 x Apexi Power FC with Hand Controller (To Suit R33 GTS-T) Very rare & discontinued now - item is 2nd Hand but works perfect, 2 minor scratches on PFC Case & Hand Controller is like new A1 - This item is a must have if doing up one of these vehicles as it leaves no restrictions - $1500.00
1 x Set of Sard 850CC Injectors to suit R33 GTS-T (side feed injectors) set of 6 still in Box wrapped in plastic -$1000.00
1 x HDI GT-Spec Front Mount InterCooler Kit - To Suit R33 GTS-T Specific - Brand New Still in original Packaging , Tube & Fin core design, core size (mm): 600x300x78, 3" Inlet & 3" Outlet, Polished finish piping with silicone joiners & hose clamps - $500.00
1 x Set of 4 CUSCO Springs (lowered Springs) Excellent Condition,only used for 5,000kms - $200.00
1 x High Mount Manifold with T3 Flange -direct bolt on to RB25DET - $100.00
1 x Sard Fuel Pressure Regulator - Brand New -Never Used - $120.00
1 x Apexi Boost Gauge 60mm - with stand - $50.00
So if you are interested in any of these items let me know -
Cheers Darrin.
Cheers Darrin.
Boost Gauge - SOLD
Sard - Fuel Pressure Reg - SOLD (pending payment)
Cheers Darrin.
Apexi Power FC & Hand Controller - Bump - $1400 or make me an offer - must sell
1 x Set of Sard 850CC Injectors to suit R33 GTS-T (side feed injectors) set of 6 still in Box wrapped in plastic - $900 (must sell)
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
