I've decided to replace all the bolt on bits first, 3" mandrel bent exhaust from the turbo back + high flow cat, then intercooler and turbo (bleed valve). Bigger fuel pump and pressure regulator to increase potential of stock injectors.
Next stage would be a Wolf3Dv4, EBC and bigger injectors when it comes time to run higher boost.
Still undecided about the turbo, but I'm leaning towards a GT25 or HKS2530 at the moment, especially after reading bbenny's posts. Would a stock turbo modified for high flow be cheaper and just as suitable?
Also, at what point would I expect to replace the AFM, and what would you guys suggest for a replacement?
Thanks for all your input so far guys, feeling more confident that I'm headed in the right direction.
Also, I haven't really considered an rb26 upgrade, I'd simply save a little extra and buy a GTR ;-)
  • 5 months later...
Ok the 2530 turbo. Is it an intrenal wastegate or external setp. I am thinking of upgrading my turbo and at first I was looking to get a Trust TD06. I know that this needs an external wastegate so it could be quite costly and probably(?) a bit laggy. Compared to the TD06, I think that the 2530 sounds like a steal at the prices mentioned in this thread. Which turbo would you guys recomend(it does not have to be one of these two either I am open to suggestion). I am after a fast street car (its an RB20 skyline wrapped in a silvia body hehe) with aprox 250 rwk.
Thanks
Hi Strange, this is what we do for 400 bhp (230/240 rwkw)...........
* Power FC with Boost Control Kit & Commander
* Split dump with mandrel 3.5" exhaust & hi flow cat
* GCG ball bearing hi flow RB25 DET turbo
* Tomei 256/260 Poncams
* Z32 AFM
* Standard GTR or Z32TT in tank fuel pump
* Pipercross panel filter in the standard airbox
* But upgrade the ambient air feed
* Standard R33/34 GTR intercooler
* 63 mm pipework from the turbo to the intercooler
* 75 mm pipework from the intercooler to the throttle body
* OS Giken twin plate clutch
* Electric fan (remove the standard fan)
More importantly, what we don't do...
^ Standard internals are fine
^ Standard compression ratio is fine ie; don't need a thick head gasket
^ Standard injectors are OK for this power level, for a bit of security an adjustable fuel pressure regulator (we use Nismo) and stretch the standard injectors 10% which is my limit
^ Standard inlet manifold is fine
^ Standard coils are fine
^ Standard exhaust manifold is fine
^ Don't need an adjustable exhaust camshaft pulley, the Tomei Poncams are timed perfectly out of the box
For 250 rwkw we find the standard injectors won't stretch, so we use 550 cc and then we don't need the adjustable fuel pressure regulator. The GTR/Z32 pump is at its limit at 250 rwkw on some cars, so you may find an upgrade there is necessary, we go straight to Bosch 044 in those cases.
Hope that helps
We made 247rwkw with a standard engine from an rb20.
The mods it had were:
.64 T04e
Turbo smart 45mm External Gate
Apexi GTR front mount
fuel Tronics Chip
Bosch Fuel Pump
3.5inch exhaust
Adjustable fuel pressure reg
and a Turbo smart boost controller. It made this power on 21psi. It had full boost at round 5k and rev'd out to 8k Sometimes even more. The car also ran a 11.8 @ 116mph.
The new owner of this car now re-sides in Newcastle.
    • If you want to do the wiring, the GTT engine ecu has the same pinouts extra that the seperate TCM in the NA car has. You can literally grab the wires/pins that lead into the Seperate TCM and wire them into the corresponding pins in the GTT Engine ECU. You could then in theory Nistune it. I realised this when everyone put it in the too hard basket and I actually looked at the f**kin R34 manual. This is after I had previously had a seperate aftermarket TCM controller in my original N/A chassis car and a very built gearbox from a GTT, running a seperate Haltech engine ECU. I ran into this issue when I re-shelled the car into a GTT shell, so my aftermarket TCM was no longer plug and play, because the loom/modules were not present. I was pretty livid when realizing just how simple the original fix actually was. It sat for 3+ years at various workshops trying to find a solution. In practice none of this is a worthwhile idea for a lot of reasons, generally surrounding the shitness of the NA auto, the autos in general that come with skylines, and the NA engine and lack of gains. The gearbox is specced for the 2.5L N/A and barely at that level. If you have to pay anyone any money to do any of this, that is money spent on manualizing the car and it's not even close in terms of a comparison. Learning to drive manual is simpler than going through the pain of dealing with the N/A gearbox and he'll have fun to boot.
    • Semi-correction to my blanket statement that you can't bend rubber hoses. It seems that you can get most of a result, by doing as this guy does. I wouldn't promise that the bends will stay in the hose forever. I think if I found they wouldn't stay, I'd get a larger hose and cut some 90°s out to go over the bends I wanted to be in the smaller hose, as a reinforcement.
    • Just a heads up. Mine has just failed. When i turn the car on it just reboots everytime then the word "Android" shows up then goes to a black screen. I've aksed the company i got it from for some help but it's passed their 90 day return so they wont help. I have to swap back to my old system this weekend 😭
    • Does the car have to stay auto? If so, you might be looking at a ZF swap in future.
    • Yeah its tuned relatively conservatively being dynoed at 525hp with every bolt on and top end of the motor built wtih HKS vcam and springs etc.
