Had a search and cant really find a definitive answer so thought I'd throw this out to the experts..well hopefully experts.
Ok had my current car here (GTR33) in Japan for just under 2 years. Its currently under going some fairly extensive engine mods etc..
linky... http://www.skylinesaustralia.com/forums/Hk...il-t246240.html
Anyway what I'm trying to find out is with the private import ruling, how long can you spend out of the country your living in..e.g I heard 6 weeks thrown about but is in a 1 year period or over the time you have lived in the foreign flamin mongrelry.
Say for instance does the 6 week or whatever get reset each year e.g say from aug 2008 until aug 2009 I spent 40 days out of Japan will this get reset from beginning of september 2009.
Basically from the above period I've been out 22 days so far (5 this year) but have couple of business trips lined up to korea which will take me close to the 6 week mark. What i'm trying to find out is will this get reset like I said at beginning sept or would the 6 week period be for this year.
If I go over this period I'd have to change evrything back to stock and do a normal import, what would be a ball park figure. I have all the original parts.
By the way I'm looking at sending the car late november
Any help be great
Bassically what theyare looking for is the shaken sho with your name and 1st date of registration to prove when you took ownership.
japnese drivers lincense
your car park certificate and contract.
full copy of your passport to prove you have been in japan for no less than 12 months , you can do trips outside japan its no problem but just minus the days you spent outside japan to calculate the 12 months.
insurance documents.
invoice for purchasing. and receipt or Bank transfer copy.
all these documants provide proof of your legal use of the vehicle whist your living in japan and importantly a lot of dates showing the 1st registration is correct.
you can find all the info on the website http://www.infrastructure.gov.au/roads/veh...cles/index.aspx
hope this helps
hope this helps
Cheers for that..
I've been here on and off for going on 9 plus years last 3 with proper visas and last 20months only been outta the country for the 20 odd days.
Cars been shakened in my name the whole time I've had it, same as car park and have had Jap licence for 2-3 years so hopefully all will be gold.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
