hey all after upgrading my kit and changing to a dump+front pipe im selling the following S1 parts
3" Front pipe to suit stock dump pipe, no gaskets included. i think its stainless steel but the heat has changed it toa light brown, also has a light graze underneath.
$100
Mspec front bar, stock white, mint condition, does not come with indicator wire connection clip, but comes with wireing, a connection clip will need to be sourced, should be easy enough from another nissan.
$200
Mspec? sideskirts, stock white, condition is a bit rough on the edge along the doors, a respray might be needed for the fussy.
$100
Stock rear bar, stock white, good condition apart from a small paint crack that i touched up seen in the pics, a respray will be needed for the fussy.
$100
Aftermarket GTR grill, not painted, never fitted.
$50
Parts are for pickup only, im in SE suberbs melbourne.
https://www.sau.com.au/forums/topic/269296-fs-r33-mspec-bodykit-front-pipe/
$100
$200
$100
$100
$50
Is there any chance you could send the grill to mackay, I know you said pick up only though i thought i would try
  • 4 weeks later...
items are still for sale
ADDED
o2 sensor origional
i thought my o2 sensor was buggered but when i replaced it nothing changed, so im assuming the origional o2 sensor is still fine and for sale - $30 pickup
ADDED
2 inch split dump pipe, bought from JJR, i have hand filed out the split pipe hole properly as they come a bit smaller, only seen 100km as upgraded to 3 inch bellmouth
$100
