Hey all.
Got a new turbo bolted on, a Garrett GT30R-IWBB hybrid with ported Nissan front/rear housings
Nissan 45V4 Front ported / modified Intake housing
Nissan 6-bolt Rear ported / modified Exhaust housing
Modified Water and braided Oil lines, Gates oil return pipe
Garrett ball bearing core, internal wastegate, GT3071R
Garrett plate # IMM120880 700177-3
Compressor
Wheel Dia Trim A/R
Ind-53.1mm Exd-71.0mm 56 0.50
Turbine
Wheel Dia Trim A/R
56.5mm 84 0.64
Modified by ATS Adelaide Turbo Services - $2500 kit price
http://www.turbobygarrett.com/turbobygarre...1R_700382_3.htm
Everything is on after a little drama; split oil return pipe on rundown test, fixed.
Using 3.5L of Penrite 15-50w, 1L of Fuch 10-40w, and added 600ml with oil additives, such as Wynns Supreme Oil Charge & Nulon Performance Engine Treatment
in 11 days the oil + fuel filters will be changed and oil will be 5L of Martini Racing Sint 60R/T 10-60w
In that time the RB25det is running a tune to suit the previous Highflow turbo, a Slide Nissan hybrid with journal bearings
for the next 11 days I intent to baby it mostly, but can adjust the Apexi SAFC-II and SITC piggybacks on the fly. As it is she's running rich atm.
Any preferences in the way to "Run-In" a new garrett ball bearing turbo?
Should the radiator fluid be changed again in 11 days before the dyno tune?
Any thoughts on ramping on the turbo, ie I havent gone past 7psi yet, mainly going to 2psi, hold then back off then 4psi, hold then backoff then 6psi, ramping it as such.
Going to do a little run tonight in the Hills, want to ramp it thru to 14psi for 100kms or so, build up the heat and get some wear into the turbo / oil.
Wont be holding down the throttle or giving it all until after the dyno tune on 21st May.
Any thoughts on driving until then, to run-in a ball bearing turbo?
cheers. Hopefully the tune reaps 240rwkw. we'll see.
Tangles
Engine:
Ryco Z201 fuel filter, Ryco Z145 oil filter, blended oil
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic shift kit & auto service kit
Koyo Radiator upgrade
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-groove spark plugs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Aerospeed adjustable exhaust cam gear pulley wheel
Greddy remote oil filter relocation kit & Fujimoto sump plug drain valve
Nismo adjustable fuel pressure regulator
Nismo Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system (turbo to cat)
3inch high-flow metal race cat
3inch cat-back exhaust system with Kakimoto Gtr racing free flow muffler
Cold Air Radiator air guide (feeds radiator / pod / intercooler)
Cold Air Induction aluminium box w/ lid setup, foam internals, using standard snorkel air feed
Trust 600x400mm FMIC bar & plate, with custom return air feed pipe kit
Apexi power intake pod filter
Apexi electronic boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 1bar and 1.1bar
HKS heavy duty turbo actuator
Garrett GT3071R- 700177-3 Internal Wastegate Ball Bearing Turbocharger + Nissan 45V4/2UI housings
Toshi ecu remap, tuned by Boostwerx
Ported headwork including new valve seals, valve seats and valve guides
EPP Clear camgear timing cover
Cometic head gasket 87mm x1.2mm
Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
ARP head stud kit
Tomei 256 intake / 256 exhaust poncam gear set
Tomei 8.8mm high lift springs
Tomei oil gallery restrictor
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear adjustable swaybars
Dayz adjustable engine swaybar, custom boot swaybar
Whiteline front castor kit
Whiteline rear subframe alignment kit
BJR Graphite 17inch rims with Marshal Mactrac TX tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, front and rear
DBA slotted front brake discs
Benidx Advance front and Heavy Duty rear brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Razin volt stabiliser kit
Car alarm
https://www.sau.com.au/forums/topic/269306-running-in-a-turbo-results-gt3076/
Well that compressor and turbine map mean zip now that the cartridge is in not std housings - for the wheels .
I don't know why they didn't just offer you a real GT3071R IW (700177-5023 cartridge) and tell you to buy/make a dump pipe .
You are going to have to source non std oil and water plumbing anyway so what they sold you isn't going to be that much easier to get up and running .
A .
Late edit , count your compressor blades because GT3071Rs all use the same compressor wheel and it isn't 7/14 bladed .
Have a look for the cartridge number on the turbos ID tag , it should say 700177-xx . The "-xx" numbers will tell the story .
Edited by discopotato03
Ive bolted it on, as it comes with a full kit. Everything adapted ready to go.
Used thick red Gates rubber joiner for the oil return, everything else is Speedflow fittings
Took off and sold my old Slide turbo for $100 less than original cost 3yrs ago, and bolted this one up
took me a while, a bit of help on one day when I was pretty sore, but all in all a project thats finished bar the tune
its a ATS GT30R highflow, meant to be the better than the GCG bbiw highflow
im sure that mod list doesnt have squat to do with "running in" a turbo.. hahah.
And as far as im aware, bolt it on, and go for gold. From what iv read on here theres no such thing as running in a turbo. Just do it.
yah its blended but only in for 9 more days. wont see anymore than 400kms.
then oil will be 5L of Martini Racing Sint 60R/T 10-60w
as is, she's a real beaut !! GT30/T04S ATS RB25 hiflow + cams/head-work. sounds fricken amazing ;)
:P
I guess Ive figured its all good. Everything is running well, and screams so so fast thru the rpm-range.
awaiting a cheapo racing seat, fit up the rear swaybar, fix heatercore & 3xguages & regas a/c.
thats it
all up ~ $43,000 after 4yrs
:happy:
Long post for a simple question
Turbos - do not need running in, if correctly assembled.
Bolt in, Boost up, simple
Completely agree. Journal bearing or BB, shouldn't matter. If something were touching to get "worn in correctly" it's going to lunch itself (is that correct aussie slang? :happy: ) anyways.
Running-in in general terms it is not required but recommended only sleeve bearing turbos. We had a brand new TD07 on a RB25det, by tuning straight after installation you notice the boost curve kicks in more and more advanced as you flooring it on the 4th gear. car picked up lot more mid rang few weeks later with boost advanced by almost 500RPM. I'm pretty sure lot of tuners have seen the same thing and will tell you the same story.
Its got nothing to do with in build quality, its not a requirement, but a recommendation to sleeve bearing turbo owners to see the true result of their setup.
Back on the turbo topic. Is this a R33's rear housing? it looks like a AVO's .63 rear housing. If that is the case this turbo would have no isses making upto 300rwkws.
Edited by hypergear
you wont make 300rwkw with that turbo.
Rated for 270kws
I'll be happy to have 230kw without extra fueling, or 250kw with the extra injector intake manifold setup
I think you're correct with the AVO housing.... Bill @ ATS did say it wasnt a stock rear housing. looks slightly thicker, etc
edit: yep its a GT30 / T04S 60T cartridge, avo .73 rear housing, ported nissan 45v4 front housing
http://www.avoturboworld.com/pdf/gts_exhaust_housing.pdf
well Ive got to say, this turbo is much more responsive than the slide turbo.
the slide wasnt going to see 230kw on my engine, and was too small when compared to the poncams and the flow potential.
ie 4th gear 4000rpm 180kmph and the turbo was out of puff but yet the cams were just coming on-song
this turbo absolutely fricken ROX !!!! Id go out there and say its worth its coin. the slide turbo was good for under a grand, but this one being BB and .73 ar rear is much much better
anyone after a bolt on RB20 or RB25 turbo I can recommend this one
would like to see a manifold pressure graph,
cheers
