Hey all.
Got a new turbo bolted on, a Garrett GT30R-IWBB hybrid with ported Nissan front/rear housings
Nissan 45V4 Front ported / modified Intake housing
Nissan 6-bolt Rear ported / modified Exhaust housing
Modified Water and braided Oil lines, Gates oil return pipe
Garrett ball bearing core, internal wastegate, GT3071R
Garrett plate # IMM120880 700177-3
Compressor
Wheel Dia Trim A/R
Ind-53.1mm Exd-71.0mm 56 0.50
Turbine
Wheel Dia Trim A/R
56.5mm 84 0.64
Modified by ATS Adelaide Turbo Services - $2500 kit price
http://www.turbobygarrett.com/turbobygarre...1R_700382_3.htm
Everything is on after a little drama; split oil return pipe on rundown test, fixed.
Using 3.5L of Penrite 15-50w, 1L of Fuch 10-40w, and added 600ml with oil additives, such as Wynns Supreme Oil Charge & Nulon Performance Engine Treatment
in 11 days the oil + fuel filters will be changed and oil will be 5L of Martini Racing Sint 60R/T 10-60w
In that time the RB25det is running a tune to suit the previous Highflow turbo, a Slide Nissan hybrid with journal bearings
for the next 11 days I intent to baby it mostly, but can adjust the Apexi SAFC-II and SITC piggybacks on the fly. As it is she's running rich atm.
Any preferences in the way to "Run-In" a new garrett ball bearing turbo?
Should the radiator fluid be changed again in 11 days before the dyno tune?
Any thoughts on ramping on the turbo, ie I havent gone past 7psi yet, mainly going to 2psi, hold then back off then 4psi, hold then backoff then 6psi, ramping it as such.
Going to do a little run tonight in the Hills, want to ramp it thru to 14psi for 100kms or so, build up the heat and get some wear into the turbo / oil.
Wont be holding down the throttle or giving it all until after the dyno tune on 21st May.
Any thoughts on driving until then, to run-in a ball bearing turbo?
cheers. Hopefully the tune reaps 240rwkw. we'll see.
Tangles
Engine:
Ryco Z201 fuel filter, Ryco Z145 oil filter, blended oil
Davies Craig automatic transmission oil cooler upgrade kit
MV Automatic shift kit & auto service kit
Koyo Radiator upgrade
Splitfire coil packs
NGK BCPRE6 0.8mm copper v-groove spark plugs
Bosch 040 fuel pump with direct battery feed at 13.8volts
Aerospeed adjustable exhaust cam gear pulley wheel
Greddy remote oil filter relocation kit & Fujimoto sump plug drain valve
Nismo adjustable fuel pressure regulator
Nismo Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system (turbo to cat)
3inch high-flow metal race cat
3inch cat-back exhaust system with Kakimoto Gtr racing free flow muffler
Cold Air Radiator air guide (feeds radiator / pod / intercooler)
Cold Air Induction aluminium box w/ lid setup, foam internals, using standard snorkel air feed
Trust 600x400mm FMIC bar & plate, with custom return air feed pipe kit
Apexi power intake pod filter
Apexi electronic boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
Greddy Profec-B spec-ii dual stage Electronic Boost Controller, set to 1bar and 1.1bar
HKS heavy duty turbo actuator
Garrett GT3071R- 700177-3 Internal Wastegate Ball Bearing Turbocharger + Nissan 45V4/2UI housings
Toshi ecu remap, tuned by Boostwerx
Ported headwork including new valve seals, valve seats and valve guides
EPP Clear camgear timing cover
Cometic head gasket 87mm x1.2mm
Cometic gasket kit including rocker cover, intake manifold, intake collector & exhaust gaskets
ARP head stud kit
Tomei 256 intake / 256 exhaust poncam gear set
Tomei 8.8mm high lift springs
Tomei oil gallery restrictor
Suspension:
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Whiteline front and rear adjustable swaybars
Dayz adjustable engine swaybar, custom boot swaybar
Whiteline front castor kit
Whiteline rear subframe alignment kit
BJR Graphite 17inch rims with Marshal Mactrac TX tyres, 235/45/17
Brakes:
Maltech stainless steel braided brake lines, front and rear
DBA slotted front brake discs
Benidx Advance front and Heavy Duty rear brake pads
Audio:
Clarion stereo tape unit with 6-stack cd player
Clarion amp mounted to enclosure for Clarion 10inch subwoofer
Pioneer 260w 4-way front door speakers
Eclipse 80w 2-way rear door speakers
Razin volt stabiliser kit
Car alarm
https://www.sau.com.au/forums/topic/269306-running-in-a-turbo-results-gt3076/
Well that compressor and turbine map mean zip now that the cartridge is in not std housings - for the wheels .
I don't know why they didn't just offer you a real GT3071R IW (700177-5023 cartridge) and tell you to buy/make a dump pipe .
You are going to have to source non std oil and water plumbing anyway so what they sold you isn't going to be that much easier to get up and running .
A .
Late edit , count your compressor blades because GT3071Rs all use the same compressor wheel and it isn't 7/14 bladed .
Have a look for the cartridge number on the turbos ID tag , it should say 700177-xx . The "-xx" numbers will tell the story .
Edited by discopotato03
Ive bolted it on, as it comes with a full kit. Everything adapted ready to go.
Used thick red Gates rubber joiner for the oil return, everything else is Speedflow fittings
Took off and sold my old Slide turbo for $100 less than original cost 3yrs ago, and bolted this one up
took me a while, a bit of help on one day when I was pretty sore, but all in all a project thats finished bar the tune
its a ATS GT30R highflow, meant to be the better than the GCG bbiw highflow
im sure that mod list doesnt have squat to do with "running in" a turbo.. hahah.
And as far as im aware, bolt it on, and go for gold. From what iv read on here theres no such thing as running in a turbo. Just do it.
yah its blended but only in for 9 more days. wont see anymore than 400kms.
then oil will be 5L of Martini Racing Sint 60R/T 10-60w
as is, she's a real beaut !! GT30/T04S ATS RB25 hiflow + cams/head-work. sounds fricken amazing ;)
:P
I guess Ive figured its all good. Everything is running well, and screams so so fast thru the rpm-range.
awaiting a cheapo racing seat, fit up the rear swaybar, fix heatercore & 3xguages & regas a/c.
thats it
all up ~ $43,000 after 4yrs
:happy:
Long post for a simple question
Turbos - do not need running in, if correctly assembled.
Bolt in, Boost up, simple
Completely agree. Journal bearing or BB, shouldn't matter. If something were touching to get "worn in correctly" it's going to lunch itself (is that correct aussie slang? :happy: ) anyways.
Running-in in general terms it is not required but recommended only sleeve bearing turbos. We had a brand new TD07 on a RB25det, by tuning straight after installation you notice the boost curve kicks in more and more advanced as you flooring it on the 4th gear. car picked up lot more mid rang few weeks later with boost advanced by almost 500RPM. I'm pretty sure lot of tuners have seen the same thing and will tell you the same story.
Its got nothing to do with in build quality, its not a requirement, but a recommendation to sleeve bearing turbo owners to see the true result of their setup.
Back on the turbo topic. Is this a R33's rear housing? it looks like a AVO's .63 rear housing. If that is the case this turbo would have no isses making upto 300rwkws.
Edited by hypergear
you wont make 300rwkw with that turbo.
Rated for 270kws
I'll be happy to have 230kw without extra fueling, or 250kw with the extra injector intake manifold setup
I think you're correct with the AVO housing.... Bill @ ATS did say it wasnt a stock rear housing. looks slightly thicker, etc
edit: yep its a GT30 / T04S 60T cartridge, avo .73 rear housing, ported nissan 45v4 front housing
http://www.avoturboworld.com/pdf/gts_exhaust_housing.pdf
well Ive got to say, this turbo is much more responsive than the slide turbo.
the slide wasnt going to see 230kw on my engine, and was too small when compared to the poncams and the flow potential.
ie 4th gear 4000rpm 180kmph and the turbo was out of puff but yet the cams were just coming on-song
this turbo absolutely fricken ROX !!!! Id go out there and say its worth its coin. the slide turbo was good for under a grand, but this one being BB and .73 ar rear is much much better
anyone after a bolt on RB20 or RB25 turbo I can recommend this one
would like to see a manifold pressure graph,
cheers
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
