  • Replies 290
haha ill pretend i didnt see it.. just means you will have to train harder..
I really wish i could .....
I have a bad back injury, been off work for a year now and only joined the gym about 6 weeks ago and can only do really light stuff, so its not through lack of trying ..... lol lol
Just keep pluggin away ..... :)
Just keep pluggin away ..... :ninja:
well i am i personal trainer and you do know where i work so i can help you..
ill sort ya out no probs.. :)
lmao its hurting now .........
give me a bit longer before you bust my balls .....
all good mate, if you need anything let me know.
so anyways back on topic.
so all confirmed for this friday.. Nandos - cnr beams rd & gympie rd Carseldine, then on too baskins aspley..
hows about 7-30.. gives everyone a bit longer to get sorted after work..
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
