The deal is .............. lol lol
Nandos @ Carseldine around 7.15 - 7.30 ish. If there are no parks in the top carpark where the shops are there is underneath but its a bit quiet down there. Im going in to have dinner so come and grab a bite or a chair, or stand in the carpark if you wish and ill come over. :)
Not sure if we are going to baskins @ aspley after that i guess it depends on who comes and what they want to do ....
Im pretty sure michael (GABNR) was being silly when he said then over to sunnybank. I wont be going any further than aspley tonight, but obviously you can all go wherever your heart fancies after that!
Hope to see some people there, if not then im having nandos and going home!
Donna ;) (PHT34)
Haha, yeah i was. Sorry Jaxt. Sif organise a dinner in sunnybank for the northsiders.
  • Replies 290
There were 5 cars there at various times. The woolies carpark was not our brightest idea as it was pcked! Who wants bloody groceries on a friday! lol lol
Next time we will make it just at baskins aspley, bigger carpark where we can park together, good night for a first try, hope to get more next time.
Maybe thinking next week again or maybe another day if people have ideas and are goin to come.
:D
yeh the carpark was chockers at that time, but we can only try, and it will get better, i didnt mind downstairs tho it was dead down there which is good for a few reasons, - plenty of parks and no problems from the po po..
either way was good to meet a couple of people.. cyas next time.
Pfffttt. Shy.
Sure sure :D
lol. I arrived fashionably late. Luckily I had my wingman with me because I was almost too scared to get outta the car. But then once we started chatting it was all good. Bit awkward when ur orange too...
Wingman ? hmmm do go on ;)
Orange ? Did you go dressed as a skittle ? :D
Lol my besty Ryan came with me. and no I wasnt dressed as a sittle lol. Got a tan for a photoshoot today so was all stinky and bright from my tan lol
LOL yes. Well I can smell it on me... then I get paranoid that im stinking everyone out with my tan smell
Cool, I learnt something today. Spray tan stinks. I seriously didn't think that it would. Wonder what its made out of ?
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
