Looking to finally get rid of my tein coilovers and go for the more street friendly setup that Sydney kid used to recommend/supply before he disappeared off these forums.
Only problem is i don't know the specifics of what his setup was.
From memory it was:
6/4 (f/b) whiteline springs with bilstein shocks
whiteline sway bars
Can any1 confirm the spring rates and/or provide any part numbers for any of the parts above.
Also would be keen on a workshop/shop that can supply these parts at reasonable prices that anyone can recommend.
Thanks guys
Edited by Taso84
yeah i did some research into this already, and with sloazr33's help, i came up with these part numbers.
The springs he used were whiteline. I think the fronts were 4kg and the rears were ~3kg
Part numbers:
Front: Spring-coil Lowering Kit WSL - Control - 73175
Rear: Spring-coil Lowering Kit WSL - Control - 83139
The shocks are Bilstein B6 Sport
Part Numbers:
Front: #F4-B46-1873-H0
Rear: #F4-B46-1916-H0
SK's shocks had extra circlip grooves (for height adjustment) machined into the shock body. They dont come standard off the shelf with these, but you can request this from your supplier.
Also, i've been told that King Springs in a similar rate, are a better alternative.
Contact Daniel at Elite Racing. He does this exact package with the king springs.
Thanks mate, that really helpfull. I'm assuming that these part numbers were for the 33 gtst, shouldv'e mentioned that in my fist post.
Also what the diff b/w kings and whiteline springs? I was sort of leaning towards getting eibachs instead of whitelines but not sure now
yeah thats for R33. i just assumed lol.
the kings have progressive rates front and rear. I think the whitelines are only progressive rears.
Eibach would also be a good choice, but you need to be careful with matching the spring rate to the damper.
So if you stay with approx the same spring rate it should be ok.
well ideally, you leave the circlips in the standard position. (350mm centre of wheel to guard)
if you drop the height, you shorten the stroke of the shock, and you're stuffing up the whole setup. ive been warned and triple warned about this, and that's why i cant commit to using this setup.
ive tried to convince myself, but 350mm is too high. lol
anyway, i'm not an expert, so ask daniel from elite racing. he will send you a very detailed reply.
edit:
actually, i'd like to see pics of some cars that are using SK's or Elite Racing's bilstein set up to see just how high or low it looks.
caaaarn guys. shows us ur bilsteins :D
Edited by Munkyb0y
is that 325mm all around? and i know these arent bilsteins. you have the greddy type s coilovers in there.
whats the standard ride height, front and rear? anyone know?
i think i read somewhere 375mm, but not sure if thats only front.
i just picked up a set of tein super streets, and wondering how low they can go on the 33.
btw joeyjoejoeyoufknbastardilovethelookofyourcar :P
Edited by Munkyb0y
350mm on the back is perfect for me but i'd prefer around 360mm on the front to save my front bar from scraping on gutters.
So this SK setup comes with 350m (centre wheel to guard) for the front and back?
Also, i know Sydney Kid mentioned that his setup was hard enough for all tracks except maybe Phillips Island, but 4/3 seems abit to soft for track. What do u guys think?
Monkeyboy, i gather that you didnt end up getting SK's pack and went for the tein SS. Was there any reason for this other than the height that you didnt like?
i run similar rates in the stag, i think they would be fine in a GTST, aslong as you have swaybars.
It's hard enough for track work if you are using street tyres and big sway bars.
semi slicks like a stiffer spring, around the 6/5 mark, or you can run a higher spring rate again with stock sway bars. There are a few ways to achieve a similar result. Each has it's own merits and short comings.
As has been mentioned already, the main failing with this set up is the stroke of the shock. The soft spring rate doesn't help in that regard so you can end up smashing your bump stops in certain situations where stiff sway bars don't contribute.
whats the standard ride height, front and rear? anyone know? (R33)
someone answer Munkyb0y's question.....
yeah...someone answer him
Edited by Munkyb0y
well i got them for a good price vs the bilsteins which seem kind of pricey + the adjustability, and ive heard so many good reports on them.
i run 325mm and even that could be a little lower, visually speaking ofcourse....
so add an inch to that basically
that looks hot , but maybe drop the back another 10mm and will be fine :)
i agree that 350mm is to high
Have you put them in yet? What spring rates did you get and how are they?
Also what was the price differential b/w the two setups?
i bought the teins second hand, so its not a viable price comparison in my case.
but the bilsteins with king spring, or whiteline springs will set you back at least $1500 or so, depending what kind of deal you can get. thats about the cheapest i could get them (WITH circlip adjustment).
i think the teins sell for about $2100 delivered from Nengun .
I havent installed them yet. Waiting on some c spanners. They come with a 4kg spring rate front and rear i believe. Ive also heard 5kg front, 4kg rear. But either way, its not a heavy spring.
And from all accounts, they provide a very comfortable ride at soft damper setting, that can be turned up to quite stiff if you require. 16 level damper adjust.
Edited by Munkyb0y
I think this was from SK R33 GB thread
"Standard (new) height is 380 mm front and 370 mm rear"
For the OP:
Definitely get a front swaybar
BNF24Z whiteline Swaybar 24mm-h/duty Blade adjustable
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
