ok im looking at buying a front mount intercooler for my r33 and the measurements are 600x300x180 will this fit my r33 series 1 the reason why im asking this is because he says its for a r32 so wondering if it will fit a r33 and also it has 2.5 inch piping is this too small
cheers
Edited by roOts 33
https://www.sau.com.au/forums/topic/269333-r33-front-mount-intercooler/
Roots, can i ask why you are proposing an intercooler which is 180mm thick?
Alot of aftermarket setups use 76 - 100mm thick intercoolers. Having an intercooler this offers no advantage over a thinner one as the atmospheric air does not sufficiently cool the rear of the intercooler.
Also are you running a factory turbo? This seems oversized for use with a standard T28.
I know this doesnt answer your question but this is another element which you need to consider. Dont just buy a second hand intercooler setup which is wrong for your car to save $200
cheers
180mm thick? :)
I dare say the core dimensions you posted are incorrect.
There are several off the shelf kits available from traders on this forum, the majority of which use a core size around 600 x 300 x 76mm, with 2.5 inch piping, which is the standard piping size used on an RB20 or RB25.
roots-james - please ensure you do PROPER investigation before buying parts
Also before starting threads, a quick search and so on.
Logic never hurts either - an 18 centimeter cooler is a little ridiculous when you get a ruler out
Hahaha 180cm!
Why don't you get yourself a mini bar fridge and pop a hose in either end of it. Perfect front mount, may have issue with closing the bonnet though...
Me thinks the measurements are incorrect.
Ahhh mate, i tried mounting 1 on top of my bonnet. Only issue was that it drew too much currect from my Flux Capacitor. :D
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
